pt cruiser 07 neutral safety wire?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101172
Printed Date: May 14, 2026 at 7:53 AM
Topic: pt cruiser 07 neutral safety wire?
Posted By: eric pham
Subject: pt cruiser 07 neutral safety wire?
Date Posted: January 14, 2008 at 11:37 PM
Hi,
I try to install a remote start for my 07 Pt cruiser (manual trans).  Anyone know if this vihicle have an neutral safety wire ?  and where it locate at ?  Please help !
Thanks, Eric
Posted By: KarTuneMan
Date Posted: January 15, 2008 at 8:51 AM
What did you "try" to install?
Is it for a manual transmission? or an auto?
Date Posted: January 15, 2008 at 7:38 PM
For a manual transmission.
Date Posted: January 15, 2008 at 8:30 PM
If the unit you are installing is manual safe....you don't need a neutral anything....posted_image
Date Posted: January 15, 2008 at 10:42 PM
I am installing the RS-727LCD autopage.  This is my 1st time install on the manual transmission and I don't want to start in gear, if I know the neutral safety wire, that will make me feel alot better !
Thanks,
Posted By: chriswallace187
Date Posted: January 16, 2008 at 6:46 AM
Can you post a link to the install manual by chance? Autopage's website is only showing the operations manual.
Reason I'm asking is because your PT cruiser may not have a "neutral safety" wire specifically but if I look at the manual I could probably tell you what you need to hook up to make your install work safely.
C Renner's Auto Electronix
Posted By: turboneon
Date Posted: January 16, 2008 at 7:48 AM
The 727 is not designed for a manual transmission. I ran into this problem yesterday, so I have to get a different unit. I will only install the manual transmission versions for other people.
I have in install pdf file, but I can't post it due to my web hosting being down for the next 2 days.
Date Posted: January 16, 2008 at 7:56 AM
Here is a screen shot of the pinouts I just pulled from the PDF (it's 2 images).
posted_image
posted_image
Date Posted: January 16, 2008 at 1:55 PM
Ok...judging by that diagram, unless there is a wire loop to cut, a jumper to move or a programming option to work safely with a manual trans., that RS should not be installed on the manual trans. car in question.
Date Posted: January 17, 2008 at 9:51 PM
Thanks for your help guys !
Posted By: techman93
Date Posted: January 17, 2008 at 10:45 PM
You may want to get a 689m by DEI which will help put remote start into ready mode only when you do certain things with parking brake and activating remote start and getting out of car and then shutting door in a certain manor so you can remote start it after without it being in gear.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
