keypad starter kill on rs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101220
Printed Date: May 14, 2026 at 12:12 AM
Topic: keypad starter kill on rs
Posted By: audioman2007
Subject: keypad starter kill on rs
Date Posted: January 16, 2008 at 10:06 AM
I want to install a keypad starter kill to my alarm system. I have the asianwolf 8000RS in a 02 cavalier. Here is what my diagram for the keypad starter kills shows.        There are 5 wires on the keypad part: white, green, red, black, and blue        There are 5 wires on the included relay socket: yellow and white running from pin 86                                           orange running from pin 85    black from pin 87   and black running from pin 30
It shows to run the white wire from the keypad to the white wire from pin 86. Wire green wire from keypad to orange wire from pin 85. I am to cut the starter wire and run the black pin 87 to starter motor side and run black pin 30 to key side. Yellow wire from pin 86 goes to igntion wire.   Red wire from keypad to constant 12V and black gets grounded. The last wire is blue from the keypad and it says to run that to the alarm. Which wire would I run it to? Would I run it to the armed output negative 500mA?
Date Posted: January 17, 2008 at 1:28 PM
Anyone understand?
Date Posted: January 17, 2008 at 1:47 PM
Would this be the correct way to wire everything up. Everything is off the diagram I got with the keypad. But I added the remote start wire. The only wire I am not sure when to run it to is the blue wire that needs to go to the alarm. Could it go to the Armed negative output?posted_image
Date Posted: January 20, 2008 at 2:18 PM
does anyone understand the diagram?
