05 volvo s80 r/s alarm wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101239
Printed Date: May 14, 2026 at 6:29 AM
Topic: 05 volvo s80 r/s alarm wiring diagram
Posted By: almeida79
Subject: 05 volvo s80 r/s alarm wiring diagram
Date Posted: January 16, 2008 at 5:56 PM
Hi i'm also looking for wiring diagram for a 05 volvo s80 Thank's again in advance. Jason
------------- Jay
Posted By: another-kelly
Date Posted: January 16, 2008 at 9:40 PM
Audiovox lists:
WIRE COLOR POLARITY LOCATION
Battery RED (+) AT VEHICLE FUSE PANEL
Ignition 1 BLUE/RED (+) IGNITION SWITCH HARNESS
Ignition 2 YELLOW (+) IGNITION SWITCH HARNESS
Accessory 1 VIOLET (+) IGNITION SWITCH HARNESS
Starter 1 YELLOW/WHITE (+) IGNITION SWITCH HARNESS
Anti-Theft Type UNIVERSAL IMMOBILIZER
Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense YELLOW (+) IGNITION SWITCH HARNESS
Tachometer LIGHT GREEN (-) AT IGNITION COIL
Parking Lights YELLOW (+) AT VEHICLE FUSE PANEL
Brake Lights YELLOW (+) AT SWITCH ABOVE BRAKE PEDAL
