Used car, not sure which Viper model ?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10128
Printed Date: April 25, 2026 at 3:38 PM
Topic: Used car, not sure which Viper model ?
Posted By: dyamada
Subject: Used car, not sure which Viper model ?
Date Posted: February 26, 2003 at 5:18 PM
I bought a used car (third owner), the second owner doesn't know what type of alarm it is, and of course I do not either.  I know that it is a Viper / DEI alarm, but I am not sure which model.
On the back of my remote it says DEI, 2^66 Rolling Codes and then FCC ID EZSDEI485  --- What model might that be ?
Also, I've been trying to get it out of valet mode since purchasing it, but alas, I've looked under the dash and I cannot see any resemblance of a valet switch or button.  Then again, I really do not know what I am looking for.  Any ideas ?
Thanks for any help that anyone can provide!
Posted By: Velocity Motors
Date Posted: February 26, 2003 at 5:23 PM
If you can trace the wires back to the CPU under the dash and get the model number and FCC ID there, we can help you better.
Posted By: 13volt
Date Posted: February 26, 2003 at 11:15 PM
What color are your buttons and LED on you DEI remote? Also if the remote is working open your car door and press I then II then I your LED on the dash should turn off. There may not be a button to find. They might have done a ghost switch.
Posted By: dyamada
Date Posted: February 27, 2003 at 10:13 AM
Thanks for the replies everyone.  At work, so I haven't crawled under the car to look for a CPU or anything...
My remote is black, the buttons are roman numerals, and when I press any of the buttons, there is a single green led light that illuminates.  When I press I and II, my car starts up remotely. ("I" unlocks/locks, and "II" pops my trunk)
Thanks for any help!  I'll download the manual once I know which one to download.. ;)
Posted By: dyamada
Date Posted: February 28, 2003 at 1:50 PM
The led on the dash no longer blinks when I arm it, it stays on steady state.  (It does blink after I start the car, then it turns off)
In any case, I opened the door and pressed I and II and the car started ! :)  So I guess that didn't turn valet mode off.  How many different models of remote start did Viper make ?
Went under the car, and I can't see anything that looks like a CPU for an alarm..nothing is labelled as such.  Any more ideas ?
Posted By: dashrat77
Date Posted: February 28, 2003 at 8:16 PM
you might have a combination in there- such as a Viper 300ESP and a 552T or 259D or 359D.
The only way to really know is to take your underdash apart and find the brain.
