05 grand caravan, as2451 with xk532
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101322
Printed Date: April 19, 2026 at 2:02 PM
Topic: 05 grand caravan, as2451 with xk532
Posted By: ervie
Subject: 05 grand caravan, as2451 with xk532
Date Posted: January 18, 2008 at 2:00 PM
ok As2451 with XK532 the ignition wire is pink/white and this vehicle has 2 of them and yes they both have the same reading. So does it matter which one i hook up. After i had everything hooked up i have a couple problems.
1) it would start but not stay running, so i put the key in the ignition and tried again with the same results.
so i tried a take over and that wouldent work either, aswell the locks didnt work either.
so any help would be nice.
Posted By: chriswallace187
Date Posted: January 18, 2008 at 2:14 PM
It sounds like you don't have the tach programmed correctly since it won't do takeover.
Can you post a link to the remote start's install manual or at least specify what brand it is? I know the XK532 is a BypassKit piece.
Ignition should be allright - if you're in the ignition harness. IIRC on that van the 2 wires go to a common pin at the ignition switch connector.
Locks could be a number of things - post how you have them connected for more help.
C Renner's Auto Electronix
Posted By: ervie
Date Posted: January 18, 2008 at 2:26 PM
Autostart 1755 Vurtual tach and the locks go through the bypass.
Date Posted: January 18, 2008 at 2:57 PM
For the tach - try switching the voltage jumper on the side of the unit. Chryslers often don't have as big a voltage change when running.
Also, I couldn't read the install manual(I'm assuming it's got more info than the 4-page QuickStart manual), so I'm not sure if your unit's default setting is tach wire or VirtualTach.
For the locks - your XK532 should have the CHDL6+ firmware on it and not the CHDL7(the default firmware loaded on the XK532).  Is this the case?
