keyless ignition system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101355
Printed Date: April 22, 2026 at 3:17 PM
Topic: keyless ignition system
Posted By: electechjb
Subject: keyless ignition system
Date Posted: January 19, 2008 at 9:09 AM
Hello!
I'm trying to figure out how to do a keyless ignition system in my 1970 Chevelle. I've found one company (Flaming River) that makes a kit, but it's quite pricey ($599). So, if any one knows another company who makes this, or a way to build it, let me know. Any help would be appreciated.
Thanks for all your help.
ElectechJB
Posted By: KarTuneMan
Date Posted: January 19, 2008 at 1:11 PM
Do you mean remote start?
Carburated vehicles are very difficult to start.
Posted By: tedmond
Date Posted: January 19, 2008 at 4:53 PM
i think hes tryint to start the car push button style, but no need for a key. i guess this is a show car?
Date Posted: February 03, 2008 at 7:35 AM
Yes, I"m trying to start the car by pushbutton without a key. Does anyone have any info on how i can do that?
ElectechJB
Posted By: KPierson
Date Posted: February 03, 2008 at 9:51 AM
It all depends on what you want for security.
If security isn't an issue you can install a simple toggle switch for the ignition circuit and a pushbutton for the starter.
Flip the switch and push the button to start, and then flip the switch again to shut the vehicle off.
If you want to add some sort of security that is where it gets pricey/complicated.
Kevin Pierson
Date Posted: March 31, 2008 at 11:44 AM
Yes, the vehicle still needs to be secure... If it's a circuit I can build, I have no problem doing that (Im versed in component level eletronics repair). Thanks for any help you all can give.
ElectechJB
Posted By: KPierson
Date Posted: March 31, 2008 at 12:48 PM
The type of security is up to you, there really isn't a one size fits all solution.  You can do something as simple as a hidden magnetic swtich to a complete RFID package.  You could incorporate fingerprint scanning or even retna scanning.  It all depends on what you want, and how much you are willing to spend.
Kevin Pierson
Date Posted: April 05, 2008 at 2:09 AM
Trying to do something similar to the systems the oem uses w/ a key fob that reckognizes it's in the car, so the car can then be started by pushbutton. Thanks.
ElectechJB
Posted By: KPierson
Date Posted: April 05, 2008 at 5:22 AM
For a wirless security option you'll either need to be very creative or prepared to spend some money.  The OEM type transponder system isn't really a good option, as their range is terrible.  You could do something with RFID, but it is expensive and hard to integrate.
You could also do bluetooth or zigbee (probably your best choices), but both of them will required battery powered transmitters that could leave the driver stranded if the battery dies.
There are options out there, but every option has a drawback, so you will be forced to sacrifice somewhere.
Kevin Pierson
