2007 mazda 3, disarm factory alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101358
Printed Date: April 22, 2026 at 9:04 PM
Topic: 2007 mazda 3, disarm factory alarm
Posted By: weasal
Subject: 2007 mazda 3, disarm factory alarm
Date Posted: January 19, 2008 at 10:59 AM
Is it possible to disarm the factory alarm in a 2007 mazda 3 without unlocking the doors?
I got a compustar pro 900 installed and the car unlocks before the start and I had to set it up to lock after but it stays unlocked for an easy 30 seconds every time I remote start it...
Thanks!
Posted By: rhd180
Date Posted: January 19, 2008 at 11:39 AM
according to directechs, using the factory alarm disarm wire will also unlock the doors at the same time
Posted By: KarTuneMan
Date Posted: January 19, 2008 at 1:02 PM
Power up the keysence to disarm without unlocking.  RED / blk @ ign. switch. (POS)+
Posted By: tedmond
Date Posted: January 19, 2008 at 1:04 PM
Power Unlock - GREEN/ RED (-) Straight ground to unlock @ DKP
Power Lock - GREEN/ RED (-) through 1k ohm resistor @ DKP
**use relays, the outputs on your aftermarket system doesnt have the current to lock/unlock all doors.**
Alarm Disarm - BLACK/ WHITE (-) @ DKP ****
Alarm Arm - BLACK/ BLUE (-) @ DKP
****disarm requires double pulse****
