rpm increase kill?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101382
Printed Date: April 23, 2026 at 1:32 PM
Topic: rpm increase kill?
Posted By: blazin_jason
Subject: rpm increase kill?
Date Posted: January 19, 2008 at 9:32 PM
Hey I was just wondering about something. Did a search didn't find anything. Is it possible to incorporate some sort of RPM increase kill device? When the vehicle is remote started if it doesn't have the key over ride, the rpms increased to a certain level it kills it. Has it been done, can it be done? Would be for a viper 5900.
Posted By: KPierson
Date Posted: January 19, 2008 at 10:05 PM
As long as you have the tach hooked up and program then the Viper should already do this.  I believe it is around 4K RPM it is supposed to shut the car down.
Kevin Pierson
Date Posted: January 19, 2008 at 10:24 PM
Yea the tach wire is hooked up. I'll have to look into that. I was thinking something like 2k would be better.
Posted By: KPierson
Date Posted: January 19, 2008 at 10:28 PM
Better for what?  The idea is to prevent damage to the motor if the throttle somehow gets stuck while the car is remote started.
Kevin Pierson
Date Posted: January 19, 2008 at 10:53 PM
Just because in my vehicle you don't need to depress the brake pedal in order to change gears. So if someone was to try and drive it, anything slightly above idle would kill the engine. I'm not overly concerned about it, it was just something I was thinking about.
Posted By: KPierson
Date Posted: January 19, 2008 at 11:24 PM
You could always get a programmable frequency switch and hook its (-) output to the hood pin.
Kevin Pierson
Posted By: Chris Luongo
Date Posted: January 20, 2008 at 12:06 PM
If you made it really super-sensitive like you're thinking, the remote starter would probably shut down during cold starts, because usually the engine revs higher.
You could remote start the car, and sit inside and rev the engine until it shuts down, if you're curious what the threshold is. It'll be different for different kinds of cars.
Posted By: KarTuneMan
Date Posted: January 20, 2008 at 12:29 PM
so if some one were to try and drive it during remote start..... the wheel would lock and they would drive in a circle.....posted_image
Posted By: KPierson
Date Posted: January 20, 2008 at 1:01 PM
Or they would hit the brakes in a very short time, unless you happen to live on an onramp!
For insurance reasons, if someone gets in your car you want the car to move, you don't want it to shut down right away IF someone is trying to steal it.  If the car doesn't move, it is considered a break in, if the car is moved it is considered car theft.
Kevin Pierson
