ultra start remote start, transponder unit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101721
Printed Date: April 16, 2026 at 6:04 AM
Topic: ultra start remote start, transponder unit
Posted By: hasnanajmal
Subject: ultra start remote start, transponder unit
Date Posted: January 30, 2008 at 4:51 PM
Hi, im just wondering what the following awires are for?  Im using a Ultra Start remote starter 1) Anti-Grind/Starter Kill - Negative Output active during remote start. (WHAT IS THIS?) a friend of mine told me that i can use this wire for the tranponder system is that true? 2)auxiliary Bypass connector (3pin White)  the WHITE/ violet wires are for Ground While Running (-) - 250ma ground output while remote starter is active and Black is ground(-) 250ma ground output and Red is (+) - 250ma 12Volt output.  Can this be used for the transponder bypass as well?
Posted By: KarTuneMan
Date Posted: January 30, 2008 at 6:25 PM
Have you actually read the install guide?  Don't take that the wrong way, it's just that each wire has a description, and an example application...in the install guide.
The aux bypass output IS used for your bypass module. All 3 wires.
Posted By: ritopkid06
Date Posted: January 30, 2008 at 9:41 PM
This orange wire depending on the type of vehicle you are doing can be used to trigger a relay for Anti-Grind/Starter Kill or it can be used to trigger the keysense wire if your vehicle needs to see keysense during remote start this wire can be connected directly to the keysense wire in the vehicle if it has a negative keysense other wise a relay would be needed to make it positive keysense. For Anti-Grind starter kill use you would cut the starter wire in half and split it on a relay triggered by this wire.
The auxiliary Bypass connector (3 pin) is used to power a mod if your vehicle has an anti theft system that needs to be bypassed. The red wire provides power to the mod, the black wire provides ground and the WHITE/ violet is ground out while running which is used to turn the mod on and off...it turns the mod on when you hit the remote starter and turns it off as soon as you do a key take over so your vehicle never sees two keys at one time.
** Anti-Grind/ starter kill (orange wire) is also a negative out while running just like WHITE/ violet**
Hope this helps and hasn't been too descriptive or confusing.
Posted By: tedmond
Date Posted: January 31, 2008 at 7:09 AM
alright, heres the info you need broken down. The negative output is used to energize a relay for many purposes - starter-kill, anti grind, bypass activation, rear defrost, etc. now, cheap units have either or options for starter kill or anti grind. good units should have both features, so make sure you program which is best for you(unless they offer both - which they should). you cant use a antigrind to do a bypass. it acts like an immobilizer so when you arm your car, no1 can start it with the key or even by hot wiring. starter kill is nice so no one can start your car while anti grind prevents you cranking again if you already remote started. you can use the negative output during remote start to activate a bypass, but no need because your unit has dedicated outputs for bypass modules (3 pin)  The negative output triggers a relay and breaks continuity on the start wire. if you wish to use it, heres how to wire it up.
85 - constant 12v
86 - neg output WHEN ARMED - starter kill                   OR              neg output GROUND WHILE RUNNING - anti grind
87a - cut starter wire - this is for key side (ignition cylinder)
30 - cut starter wire - this is for motor side (towards car)
2) auxiliary Bypass connector (3pin White)  the WHITE/ violet wires are for Ground While Running (-) -250ma ground output while remote starter is active and Black is ground(-) 250ma ground output and Red is (+) - 250ma 12Volt output.  Can this be used for the transponder bypass as well?
yes this will be used to trigger the bypass module ONLY if needed when your vehicle has a factory anti theft system. most bypass modules require constant 12v and ground, but i suggest you dont use the red and black from that 3pin harness. just connect the bypass to the appropriate wires and use the WHITE/ VIOLET to trigger the bypass during the remote start sequence. hope this fills you in.
Date Posted: January 31, 2008 at 7:52 PM
Tedmond I install ultra starts on a daily basis and have done hundreds of them and your last response interested me. Are you saying you only use the WHITE/ violet in the mod harness and dont connect the 12v or ground and it works?
Date Posted: January 31, 2008 at 7:54 PM
or are you saying you get power and ground else where?
Posted By: tedmond
Date Posted: February 01, 2008 at 7:16 AM
oh sorry if i didnt make it clearer =) i was tryin to say get power and ground from other locations insted of tapping off the unit.
Posted By: splaudio
Date Posted: February 01, 2008 at 5:45 PM
no use the starters brain for the + and - for the bypass module that is what it is there for...
Date Posted: February 01, 2008 at 6:05 PM
exactley !
