05 santa fe remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101950
Printed Date: May 12, 2026 at 5:35 AM
Topic: 05 santa fe remote start
Posted By: gustave1234
Subject: 05 santa fe remote start
Date Posted: February 06, 2008 at 3:56 PM
Hey guys, if installed a few remote starters but I'm trouble with this one. It's for my 05 Santa Fe and i believe I found all the wires but one for the barking break. Yes it's a standard, the first one i install a remote in.
So my question is has anybody installed a remote start into a standard 05 Santa Fe? And does anybody have the wire diagram to be used? I usually use Bypass kits when installing but none are available for my Fe. Can it be that I have to bypass a key sense and the factory alarm before starting?
Any help would be greatly appreciated I'm at my wits ends.
Dan
Posted By: KarTuneMan
Date Posted: February 06, 2008 at 5:59 PM
First off, be certain the unit you are installing is designed for a manual transmission. (you read the forum rules....correct?)
12 VOLTS Orange & Red Ignition switch harness   +
 IGNITION Blue (12 gauge) Ignition switch harness   +
 ACCESSORY Pink Ignition switch harness   +
 STARTER Blue (smaller gauge) Ignition switch harness   +
 KEY SENSE Brown Ignition switch harness   +
 TACH SIGNAL WHITE/ black SEE NOTES
 This wire is found at the vehicle computer located behind the center console. Pin-3 on 26-pin connector on the 2.4L Automatic. Pin-8 on 12-pin connector on the 2.4L Manual. Pin-17 on 40-pin connector on the 2.7L model. You can also use an injector on any of these vehicles.
 FUEL INJECTOR Opposite from Pink At any injector on engine   AC
 LOCK Yellow/black or Yellow In driver's kickpanel   -
 The wires may change color at a connector near the driver's kick. Both possible colors are listed.
 UNLOCK White or WHITE/ black In driver's kickpanel   -
 DRIVER LOCK MOTOR Gray In driver's kickpanel   +
 DRIVER UNLOCK MOTOR White In driver's kickpanel   +
 DOORPIN Yellow In large wire harness in driver's kickpanel   -
 HOODPIN Green or Pink At junction block under driver's side dash   -
 TRUNK PIN BLACK/ orange In large wire harness in driver's kickpanel   -
 FACTORY ARM SEE NOTES
 The optional factory alarm system arms and disarms exclusively with the factory transmitter. There is no way to arm or disarm the system otherwise. For remote start installations, it would be best to add keyless entry and discontinue use of the factory remote.
 FACTORY DISARM SEE NOTES
 BRAKESWITCH GREEN/ black At switch above brake pedal   +
 PARKLIGHTS GREEN/ orange In top right plug on fusepanel   +
 Found on a WHITE connector. There is another GREEN/ orange in a black connector that tests as a parklight wire. DO NOT use this wire as it has been know to cause problems with the light module.This wire is found at the vehicle computer located behind the center console. Pin-3 on 26-pin connector on the 2.4L Automatic. Pin-8 on 12-pin connector on the 2.4L Manual. Pin-17 on 40-pin connector on the 2.7L model. You can also use an injector on any of these vehicles.
 HAND BRAKE Green or GREEN/ black At switch on handbrake lever   -
 HORN Brown At steering column   -
The clutch is red @ the switch. Connect your starter out form your R/S to this wire INSTEAD of the starter wire at the ign. harness.
Date Posted: February 07, 2008 at 10:19 PM
Hey KarTunMan,
I'd like to start by thanking you for the speedy reply. The remote start unit is for manual transmision. You mentioned driver lock motor  and driver unlock motor what do they do and are they needed for simple remote strating?
Thanks again.
Dan
Date Posted: February 08, 2008 at 8:56 AM
Just go to lock, and unlock. Some tech info is simply given on a FYI basis. Gives you options, ya know.
