2008 jeep liberty remote start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101952
Printed Date: May 12, 2026 at 3:38 AM
Topic: 2008 jeep liberty remote start?
Posted By: hr220a
Subject: 2008 jeep liberty remote start?
Date Posted: February 06, 2008 at 5:20 PM
Hey. I neeed wiring info on a 2008 Jeep Liberty. thanks.
Posted By: KarTuneMan
Date Posted: February 06, 2008 at 6:10 PM
I think your only luck is gonna be with DEI. Astro, and wiremagic have the big zero.
Posted By: tedmond
Date Posted: February 06, 2008 at 7:13 PM
Posted By: offroadzj
Date Posted: February 06, 2008 at 9:23 PM
dei doesnt have it either... atleast, they didnt when i checked about 2 weeks ago
------------- Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
Posted By: hydroz_23
Date Posted: February 06, 2008 at 9:28 PM
same as a dodge nitro, except is has a horn wire
Date Posted: February 06, 2008 at 9:31 PM
heres the Nitro I would imagine you get the horn at the relay under the hood. | PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES | | | | This vehicle is equipped with a TRANSPONDER passive anti-theft system. A keyless bypass module may be available for remote start installations, contact your supplier to find out. If one of these modules is not available to you, refer to our transponder bypass diagram. |
| | 12 VOLTS | Red | Low in driver's kickpanel | + | | IGNITION | Pink/white | Ignition switch harness | + | | ACCESSORY | Violet/brown | Ignition switch harness | mux | | | | Required ground through a 600-ohm resistor to activate accessories. See the provided diagram. |
| | STARTER | Violet/brown | Ignition switch harness | mux | | | | Required ground through a 180-ohm resistor to activate starter. See the provided diagram. |
| | TACH SIGNAL | Opposite from BROWN / gray | At any of the coils on the engine | AC | | FUEL INJECTOR | Opposite from BROWN / white | At any of the fuel injectors on the engine | AC | | LOCK | Violet/green | DKP harness from driver's door | - | | | | Requires a 1-kohm resistor to lock and a 185-ohm resistor to unlock. |
| | UNLOCK | Same wire as lock | DKP harness from driver's door | - | | | | Requires a 1-kohm resistor to lock and a 185-ohm resistor to unlock. |
| | DOORPIN | SEE NOTES | | | | | | Driver's door - Violet/blue, front right door - Violet/white, rear left door - Violet/gray, and right rear door - Violet / YELLOW. All 4 wires are located in the black plug on the left side of the steering column. |
| | HOODPIN | Violet/blue | At pinswitch under hood | - | | TRUNK PIN | Violet/orange | In black plug on left side of steering column | - | | TRUNK RELEASE | Lt.GREEN/ blue | In driver's kickpanel running to rear of vehicle | Rev Pol | | | | This will only unlock the trunk lid. |
| | FACTORY ARM | Pulse lock & LF doorpin | | | | FACTORY DISARM | Through OEM remote only | | | | BRAKESWITCH | Dk.GREEN / WHITE | Large harness low in driver's kickpanel | + | | PARKLIGHTS | WHITE/ violet | Large harness low in driver's kickpanel | + | | HAND BRAKE | GREEN / WHITE | At switch on handbrake lever | - | | HORN | Dk.GREEN/ violet | At steering column | - | | VSS WIRE | GREEN/ brown | In Green plug at PSM on pass. side fender under hood | AC |
Posted By: hr220a
Date Posted: February 06, 2008 at 9:44 PM
cool. That's a ton better than going without anything. DEI didn't have it. thanks
