2005 frontier cc lock/unlock? code alarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=101954
Printed Date: May 12, 2026 at 2:47 AM
Topic: 2005 frontier cc lock/unlock? code alarm
Posted By: jfent
Subject: 2005 frontier cc lock/unlock? code alarm
Date Posted: February 06, 2008 at 5:56 PM
Ok for the alarm gurus...ok i installed the alarm about 2 yrs ago..everything worked perfect...now today i get in truck go to next stop...alarm vehicle...locks perfect...come back alarm will not unlock doors...happened all day...locks but will not unlock...where should i be looking to fix this problem?
Posted By: KarTuneMan
Date Posted: February 06, 2008 at 6:01 PM
Check the out put to unlock @ the alarm first.
Then go to the lock wires and make sure it's all still in tact.
Posted By: jfent
Date Posted: February 06, 2008 at 6:14 PM
its gotta be somewhere from the alarm...if i use unlock from driver door all locks will unlock...kinda annoying...because when u start vehicle it will auto lock doors...then when ignition turns off will auto unlock...except for today posted_image ill check wires from alarm...anything i can check why im in there? thanks
