94 Accord Remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10207
Printed Date: April 23, 2026 at 10:37 PM
Topic: 94 Accord Remote start
Posted By: nemesis
Subject: 94 Accord Remote start
Date Posted: February 28, 2003 at 1:10 PM
Q1 - I've just installed a remote start car alarm into my 94 Honda Accord and it's working just great except it's not working right. when i remote start the car it starts like a dream and will idle for a few secconds befor it turns it's self off.  I'm thinking it has something to do with the tach wire because i didnt want to run another wire through the fire wall i found a blue wire that i thought was it when the car was off it read 0v and when it was on i got a reading of .5v or so i thought that this was kinda low but i was trying it, is this the wrong wire and if it is are there any places i could check for the right one?
Q2 - another problim i had was finding the dome light wire. for the dome light i was told to look for the 20 pin connector to teh left of the steering column and then find the BLACK/ WHITE/ silver doted wire but unless i'm blind i cant find that i think i've found the connector but the wire is not there.
Q3 - one last simple thing (i hope) is there a way to connect the lights to the alarm so they flash with the alarm? they flash on lock and unlock but not for the alarm.  thanks for your time
Posted By: jrilla
Date Posted: February 28, 2003 at 1:25 PM
Q1:Sounds like atach problem to me too. There should be a blue wire at the distributor. Otherwise you can grab an injector wire. There are 2 wires at each injector, every injector will have 1 wire that is the same color, grab anyone of the wires that are uncommon. If you have a tachless mode, it may work fine.
Q2:You are supposed to use the door trigger: which is blk/wht in a gray plug to the right of the steering column and it is (-)
Q3:What unit are you working with? Most alarms flash the lights when the alarm is going off. There are ways to get around this, but I find it wierd that they would not flash when the alarm is triggered.
J Rilla
Owner/Installer
Posted By: ViperATC5
Date Posted: February 28, 2003 at 1:57 PM
what remote start unit did you install? It may in fact be the correct wire - but for some remote start units you have to program the unit to learn the tach signal
Posted By: nemesis
Date Posted: February 28, 2003 at 3:38 PM
i dont know the name of the manufacture but the unit is a FM-2009 i got it on ebay i've sence found the same unit at https://www.asianwolf.com/2009INFO2.htm i could try to find the tach wire under the hood but i really dont what to put another wire through the fire wall when i knwo that the wire has to come it some where and i duble checked the lights and found that the front come on but i dont know about the back the nabors are starting to get mad at me for testing it... to much noise posted_image
Posted By: jrilla
Date Posted: February 28, 2003 at 3:46 PM
Did you try the tachless mode? I would try this first and if that does not work, then you should just run another wire into the engine, I mean it cant be that hard, you should already have 2 wires going through the firwall already, one more cant be too hard.
That alarm should flash your parking lights when the alarm is triggered. I am sure that if it flashes the front then the back are flashing too.
J Rilla
Owner/Installer
