02 explorer first time remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102164
Printed Date: May 13, 2026 at 12:34 PM
Topic: 02 explorer first time remote start
Posted By: egpineda83
Subject: 02 explorer first time remote start
Date Posted: February 13, 2008 at 2:10 PM
First off thanks to all the help in advance. i have done alarms before but not remote start. so im kind of a newbie to this. So i thought its about time i learned. I just bought the prestige aps997a and have done everything except the remote start. I started wiring the remote start 3 days ago, and i hit a dead end. i have gone through every single forum here about this alarm and my truck and have not gotten anywhere. So here are my 2 problems first yesterday after finishing up my parking lights stopped working. I checked my fuses and everything is fine, i then saw that my power seat was not working either i don't know if i blew a fuse or what, so next is the problem with the remote start, so i have the 6 pin main power harness and i hooked up purple(acc) to cars light green, blue (ign.1) to cars red w light green, red (bat.2) to cars yellow, red w white(bat.1) to cars yellow, yellow(start) to the cars red. its got the inhibit relay and said it goes on the starter side so i hooked it to the black wire on the relay which is the side going out to the starter. the last wire is green(ign.2) which i didn,t connect since my truck does not have that. Now besides that i connected the GREEN/ orange which is tach wire to one of the injector wires i just avoided the WHITE/ blue like most threads said. last i hooked up the BROWN / black (+) shutdown from brake light switch to the tan/red on the trucks brake pedal switch. I tried to detail as much as i could. I will appreciate all replies.
------------- Gama
Posted By: tedmond
Date Posted: February 13, 2008 at 2:32 PM
your unit might not be remote starting because you have your hood pin constantly on GROUND. since 02 explorers only come in auto, make sure you have grounded the E-Brake Wire from the unit. THe Ebrake can also be found as Neutral or Hand Brake Safety - just secure this wire to ground.
Date Posted: February 13, 2008 at 4:25 PM
the unit only has that BROWN / black shutdown brake wire, besides that its got a parking brake input but it says to only use that when you use a turbo timer so i don't know what other wire it could be. If its any help here is a link to the manual. on the last page is all the wiring https://www.audiovox.com/manuals/installation/1287402.pdf When i try to remote start it just says inhibit on the lcd remote. ------------- Gama
Posted By: chadwa2003
Date Posted: February 13, 2008 at 4:33 PM
Did you program the tach wire?
Date Posted: February 13, 2008 at 4:41 PM
yes i did program it, then i disconnected the module when i started the remote start so i don't know if it unprogrammed. But i don't know how to program it now cause my parking lights won't flash and i don't know how to get that fixed yet. so i won't know when its actually programmed if i tried. ------------- Gama
Posted By: mikvot
Date Posted: February 13, 2008 at 4:58 PM
Do you have the 2 pin remote start on/off switch plugged in and turned on?
Date Posted: February 13, 2008 at 5:01 PM
Yes its plugged in and to the on position. ------------- Gama
Date Posted: February 13, 2008 at 5:56 PM
First of all you need to pull all the fuses in your truck to find out why the parking lights aren't working. Check both fuse boxes and remove each fuse and visually inspect it. You should find a blown fuse somewhere but you need to find out why you blew the fuse in the first place
Date Posted: February 13, 2008 at 6:06 PM
I just checked all my fuses they are all fine. the weird part is that my power seats aren't working either and each one has it's own fuse, but they are both good.
------------- Gama
Date Posted: February 13, 2008 at 6:09 PM
Do your turn signals or four ways work
Date Posted: February 13, 2008 at 6:14 PM
Also did you test all your wires with a dmm before making connections?
Date Posted: February 13, 2008 at 6:21 PM
My turn signals as well as my headlights work, its just the parking lights the cluster lights and the seats. I had a wiring diagram but some wires were wrong so i used a test light for a few wires. Thanks for the replies by the way. I really want to finish this and not have to take it to a shop.
------------- Gama
Posted By: mikvot
Date Posted: February 13, 2008 at 6:31 PM
Make sure you didn't unplug anything during the install.....maybe when putting zip ties on the wires. Also make sure that no wires have been cut or broken in the ignition harness(besides your starter kill) If everything looks good, i would agree with chadwa...theres gotta be a fuse blown somewhere. Did you check the fuse box under the hood? I know you said you already checked inside, but check every last one of them.
Date Posted: February 13, 2008 at 6:34 PM
ok ill go pull each one out again just to make sure. How would i test those big relays to see if they are fine? ------------- Gama
Date Posted: February 13, 2008 at 7:20 PM
All fuses were fine, i have taken out a bolt that goes in the foot brake pedal close to the firewall, and as soon as i put it in the parking lights came on. i guess it had some ground wire hooked up to it, thats a first. So now im stuck with the remote start i will program it and let you know what it did. ------------- Gama
Date Posted: February 13, 2008 at 7:42 PM
ok i just reprogrammed the tach and i guess it has reset it, but it still does not even show signs of turning on. The remote justs says inhibit on it like before. FYI i have not installed a bypass yet, but i know that if i have the key in it it will crank or even without the key the lights would at least turn on it just would not start. My bypass its on its way but i want to have it ready just to install that bypass and not have to deal with this at that time so i appreciate your help really much. So hopefully you can guide me in the right direction.
------------- Gama
Posted By: tedmond
Date Posted: February 13, 2008 at 8:38 PM
look at the 2 pin connector (control switch). take the BLACK/ white, that should be the NSS wire, connect that to ground and it should start.
Date Posted: February 13, 2008 at 9:13 PM
Thanks to all that helped. I was reading some other threads in a different site and my mistake was in connecting the shutdown wire to the positive side of the brake switch and it went on the negative. Thanks for your help anways.
------------- Gama
