08 escape locks/disarm?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102219
Printed Date: May 13, 2026 at 1:46 AM
Topic: 08 escape locks/disarm?
Posted By: todds440
Subject: 08 escape locks/disarm?
Date Posted: February 15, 2008 at 7:17 AM
Doing R/S install in the coming weeks on a 08 Escape.  Previous years you could tie doorlocks and arm/disarm at the the same point and use double pulse on your unlock/lock.  For those of you that have done o8's whats the easiest way to do locks and disarm??  Thanks
Posted By: KarTuneMan
Date Posted: February 15, 2008 at 9:02 AM
To lock and arm you trigger the wires that connect to the push pad on the outside of the door. 7/8 9/0    YELLOW /GREEN, PURPLE / green. Triiger at the same time diode isolate.  drivers kick harness
Disarm ..... PURPLE / brown. drivers kick harness    Unlock is yellow/purple  drivers kick harness or SJB .   ALL are negative.
Posted By: todds440
Date Posted: February 15, 2008 at 11:41 AM
Thanks for the info.  For those of you that have done one .  How hard?  Any tricks?  thanks.
Posted By: mikvot
Date Posted: February 15, 2008 at 5:25 PM
Easy vehicle to do. Done quite a few remote starts, and probably 50 alarms on these and never seen one with a factory alarm.
Posted By: todds440
Date Posted: February 15, 2008 at 6:13 PM
Do any of the 08's that youve done have a GEM module?  Or has Ford done away with this setup?  The reason I ask  is all of the wiring info for the 08 escape doesn't mention a Gem module.  Which Pats bypass are you using?
