Wiring info for 2002 Chevy Tahoe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10224
Printed Date: April 23, 2026 at 1:40 PM
Topic: Wiring info for 2002 Chevy Tahoe
Posted By: merks
Subject: Wiring info for 2002 Chevy Tahoe
Date Posted: February 28, 2003 at 6:38 PM
Can anyone help with the color codes for a 2002 Chevy Tahoe? Are they the same as 2000? Also what is needed to add remote strat to the same vehicle. I have a Clifford Cocept 200 and the intellistart module, is anything else needed? This will be my first time installing this unit(remote start), and just for good measure it will be in my personal vehicle! Thanks for your help.
Merksposted_image
Posted By: the12volt
Date Posted: February 28, 2003 at 6:47 PM
|       ITEM    |     WIRE COLOR   |POL|       WIRE LOCATION      |
|              12V|red               |+|ignition harness          |
|          STARTER|yellow            |+|ignition harness          |
|         IGNITION|pink              |+|ignition harness          |
|  SECOND IGNITION|white             |+|ignition harness          |
|        ACCESSORY|orange            |+|ignition harness          |
|       POWER LOCK|lt. blue          |+|brown plug at BCM *1      |
|     POWER UNLOCK|white             |+|brown plug at BCM *1      |
|       LOCK MOTOR|gray              | |drivers kick panel        |
|     UNLOCK MOTOR|tan               | |drivers kick panel        |
|    DISARM DEFEAT|tan               | |passengers kick panel     |
| PARKING LIGHTS +|brown             | |lt. blue plug at BCM *1   |
| PARKING LIGHTS -|white             | |lt. blue plug at BCM *1   |
|       HEADLIGHTS|white             |+|lt. blue plug at BCM *1   |
|     DOOR TRIGGER|*2                |-|BCM *1                    |
|FCTRY ALRM DISARM|lt.green          |-|drivers kick *4           |
|       TACHOMETER|white *5          | |ECM *3                    |
|      SPEED SENSE|dk.GREEN / WHITE    | |ECM *3                    |
|       BRAKE WIRE|white             |+|brake pedal switch        |
|     HORN TRIGGER|black             |-|brown plug at BCM *1      |
|           WIPERS|                  | |                          |
|  LF WINDOW UP/DN|blue   -   brown  |A|drivers door switch       |
|  RF WINDOW UP/DN|blue   -   brown  |A|passenger door switch     |
|  LR WINDOW UP/DN|blue   -   brown  |A|LR window switch          |
|  RR WINDOW UP/DN|blue   -   brown  |A|RR window switch          |
Notes:NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11. *2 Use tan for the drivers door located in pin B4 of the purple plug, the passenger doors are a blue/white in the lt. blue plug, and the rear hatch pin is a pink/black in the lt. blue plug. You must diode isolate these wires. *3 ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled 'red', and VSS wire is at pin 3 in the connector labeled 'black'. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the 'red' connector, and VSS wire is located in pin 50 of the 'red' connector. *4 Also found in the purple plug of the BCM. *5 Diesel wait to start wire is dk. blue (-) located at the instrument cluster.
posted_image the12volt • Support the12volt.com
Posted By: Haku
Date Posted: February 28, 2003 at 8:57 PM
Use a PLDATA to bypass the immobilizer, its much easier to install then the 555T or 555L, here is a link for one, I use these and have had zero problems.
https://sitemanager.theinternetsolution.com/hometronicz/inc/pdetail?v=1&pid=149
Hak
Siemens Autostart
