08 expedition same as 07?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102308
Printed Date: March 31, 2026 at 12:39 AM
Topic: 08 expedition same as 07?
Posted By: saskpuller
Subject: 08 expedition same as 07?
Date Posted: February 18, 2008 at 11:18 AM
I have an 08 Expedition this week and have no info on it. Is it the same as the 07? If not, does anyone have anything on it. Thanks.
Posted By: KarTuneMan
Date Posted: February 18, 2008 at 11:27 AM
Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 This vehicle is equipped with an IMMOBILIZER passive anti-theft system. Please refer to the provided diagram before any remote start installation.
 12 VOLTS Blue/red (2) Ignition switch harness   +
 IGNITION WHITE/ orange Ignition switch harness   +
 ACCESSORY Violet/blue or Violet/green Ignition switch harness   +
 ACCESSORY 2 BROWN / yellow Ignition switch harness   +
 STARTER Blue/white Ignition switch harness   +
 TACH SIGNAL Use a fuel injector
 LOCK WHITE/ black or WHITE/ brown Passenger kickpanel in fusebox or harness from door   -
 UNLOCK Blue/black or Blue/brown Passenger kickpanel in fusebox or harness from door   -
 DOORPIN See Notes Passenger kickpanel at fusebox
 Independent door triggers must be diode isolated, see diagram. GREEN/ violet, Green, Yellow, White.
 TRUNK PIN Gray/orange
 TRUNK RELEASE YELLOW /GREEN In driver's kickpanel   -
 BRAKESWITCH Yellow/gray At switch above brake pedal   +
 PARKLIGHTS Violet/gray In plug above fuses in passenger kickpanel fusebox   +
 Also found PURPLE / WHITE in driver's kickpanel
 HORN Yellow/red At steering column   -
