autopage 655 signal problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102345
Printed Date: March 31, 2026 at 10:34 PM
Topic: autopage 655 signal problem
Posted By: MikeHusain
Subject: autopage 655 signal problem
Date Posted: February 19, 2008 at 11:55 AM
I just installed an autopage 655 alarm and remote start in a 2005 mazda mpv.  Everything works great except that when the car is left parked for a couple of hours, I try to unlock the doors or remote start and I get no response.  As soon as I walk up very very close to the vehicle, it then will unlock and remote start.  Now right after it receives its first signal, I can be very far away and it works great.  It almost seems as if the unit falls asleep after sitting for a while, as soon as it receives its first signal it works perfect.  Any suggestions?  Thanks....
Posted By: tedmond
Date Posted: February 19, 2008 at 2:08 PM
check your ground.
Date Posted: February 19, 2008 at 3:04 PM
That was the first thing I did, the second thing was relocated the attenna, third thing was made sure there was sufficient voltage when the vehicle is at rest and i got 12.3 VDC which is not bad.
Posted By: Jason Ewing
Date Posted: February 20, 2008 at 12:57 AM
have you tried swapping the antenna yet?
National Product Training Specialist
AUTOPAGE INC
Date Posted: February 20, 2008 at 7:15 AM
No, i did not try that yet, I did try swapping the brain unit thinking there was a defect with it but that did not solve the problem.  I will try swapping the attenna next.  Any other suggestions..? Thanks..
