dei 528t , clarion max675vdii
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102347
Printed Date: April 01, 2026 at 12:23 AM
Topic: dei 528t , clarion max675vdii
Posted By: shagdrum
Subject: dei 528t , clarion max675vdii
Date Posted: February 19, 2008 at 1:11 PM
I have a clarion Max675VDII and am trying to work around the parking brake ground for video issue. Unlike many DVD playing headunits, you can't just ground it, as the unit needs to see a change in the ground signal. I could just install a switch, but I had read about a pulse timer relay someone had used for one of these, on another message board. The post wasn't clear on the wiring or which relay was used. I have a DEI 528T relay to use and need to know how to wire the parking signal up so that when I turn the head unit on, the parking brake ground signal is breifly interupted.
Here is what I was thinking:
BLACK: ground
Red: 12 VDC power
BLACK w/ stripe: not used
YELLOW 30 common: attach to parking brake line from head unit
BROWN 87: not used
ORANGE 87A (normally closed): ground
BLUE wire loop: uncut
Would this be correct?
Posted By: Big Dog
Date Posted: February 19, 2008 at 3:18 PM
Your BLACK/ White is your trigger. Connect it to ignition or something similar which will change polarity and trigger the timer.
I have a VRX575 USB and haven't got around to automating it . . .I have a toggle switch for now.
I'm going to activate it through an aux channel on my Viper which I can link to unlock.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: shagdrum
Date Posted: February 19, 2008 at 3:29 PM
I thought if you didn't cut the blue wire loop, that triggered on receiving negative (per the little instruction sheet). I assumed that meant that the relay sensed the unit trying to get ground and you didn't need to use the BLACK/ white.
BTW, great quote by "The Who"
Posted By: chadwa2003
Date Posted: February 19, 2008 at 10:22 PM
Not that I promote doing this but just take a regular starter kill relay
85 to power antenna wire coming off the clarion
86 and 87a to ground
30 to lt green on the clarion
Now to activate simply turn to unit to tuner then back to dvd and it's just that easy
Posted By: shagdrum
Date Posted: February 19, 2008 at 10:32 PM
Thanks for the reply...
That makes sense. However I already have the 528T pulse timer relay, might as well use it.
Posted By: shagdrum
Date Posted: February 20, 2008 at 8:25 AM
...anyone?
Posted By: Big Dog
Date Posted: February 20, 2008 at 9:03 AM
Sorry for not replying, I usually sleep overnight. posted_image
Yup. Cut the blue so it sees the transition from negative to positive as a trigger.
Posted By: Big Dog
Date Posted: February 20, 2008 at 3:26 PM
Oh, I forgot to add: "For offroad use only!" posted_image
