pushbutton led voltage
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102350
Printed Date: April 01, 2026 at 5:34 AM
Topic: pushbutton led voltage
Posted By: spaspecker
Subject: pushbutton led voltage
Date Posted: February 19, 2008 at 4:33 PM
I already have pushbutton ignition in my car, but want to replace the button I have with this one:
illuminated pushbutton
as I want the button to light up
My question is how do I wire the LED? I know I can take 12v from pretty much anywhere in the car but the spec on the button says the LED uses 1.85v - so how do I "step down" 12v to 1.85v?
Date Posted: February 19, 2008 at 4:36 PM
sorry guys, something wrong with the linky - try this link
Posted By: Ween
Date Posted: February 19, 2008 at 10:11 PM
hi,
assume that when the vehicle is running, you'll probably have more than 12 volts available then
lets make it a bit higher than typical (14.4=Vs).  forward voltage for the led (1.85=Vled) then subtract
Vled from Vs......14.4 - 1.85 = 12.55    now take this amount and divide by the forward current of the led.
from the spec sheet iled = 50mA max(you'd probably not need to run the led at max current) so lets run it
at 25 mA...... 12.55 / .025 = 502 ohms.  so start with a value around there but don't go any lower than
251.  less current equals less brightness
hope this helps
mark
