how do i add a dei 508d
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102501
Printed Date: May 14, 2026 at 4:07 AM
Topic: how do i add a dei 508d
Posted By: davesparkave
Subject: how do i add a dei 508d
Date Posted: February 24, 2008 at 11:41 AM
can i tap into the wires on my shock sensor they are the same colors on both sensors,will that affect the shock sensor if i do this?
Posted By: novice tech
Date Posted: February 25, 2008 at 7:17 AM
hey u can check in a viper 791xv manual on pg.32 and this will show u how to correctly interface your 508d with shock sensor.
Posted By: chris27
Date Posted: February 25, 2008 at 2:51 PM
You can tap the blue and green in together but you really want to ground it where you grounded the alarm and get 12V from your constant power line, not from the shock sensor.
