3 accessory wires on 02 expedition
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102538
Printed Date: April 01, 2026 at 11:25 PM
Topic: 3 accessory wires on 02 expedition
Posted By: jaurora
Subject: 3 accessory wires on 02 expedition
Date Posted: February 25, 2008 at 1:33 PM
Well,
I started an install on my expedition. There is only one ignition wire and 3 accessories. I am installing a python unit (forgot the model#) but is has an output for the ignition, accessory, and then the pink/white which can be programmed for either 2nd accessory or 2nd ignition. I really dont want to wire up another realy for the third acc, seeing that I am out of them and all three radio shacks near me are out. Does anyone know what each accessory wire does? I just want to pick the most important 2, I would figure one is for the blower and the others are for the electronics. I am unsure, possably all 3 need to be wired. I am not worried about the radio and such being on, just the blower for the heat.
The three wires that are listed are:
1) RED / blk
2) Grey/yel
3) BLACK/ Grn
Thanks in advance.
J
MECP certified (If it really means anything)
Jeremy
Posted By: chris27
Date Posted: February 25, 2008 at 2:42 PM
Don't worry about the BLACK/ grn wire.  It is for powering up the radio.  You only need the RED / blk and Grey/yel.
Posted By: jaurora
Date Posted: February 25, 2008 at 2:57 PM
Just what I needed
Thanks for your help.
J
Jeremy
