96 Bronco Rear Window
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10285
Printed Date: April 19, 2026 at 1:19 AM
Topic: 96 Bronco Rear Window
Posted By: nero7747
Subject: 96 Bronco Rear Window
Date Posted: March 02, 2003 at 12:00 AM
I'm looking to get an alarm for my bronco.  It doesn't have the factory keyless entry.  I basically want an alarm with keyless entry.  I would also like to get something else.  My bronco has a rear window that goes up and down into the tailgate with a switch or key in tailgate.  I've seen some alarms that have modules that let you roll up/down your front windows.  Could I adapt this to work with the rear?  Or better yet is there one that is made to do this?  Any suggestions on what brand to get?  I'll be installing it myself.
Posted By: Velocity Motors
Date Posted: March 02, 2003 at 6:50 AM
|              12V|yellow              |+  |ignition harness            |
|          STARTER|RED / lt. blue        |+  |ignition harness            |
|         IGNITION|RED / lt. green       |+  |ignition harness            |
|  SECOND IGNITION|gray / YELLOW    18awg|+  |ignition harness            |
|        ACCESSORY|gray / YELLOW         |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ green         |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |*1 |either kick panel *2        |
|     POWER UNLOCK|pink/green          |*1 |either kick panel *2        |
| PARKING LIGHTS +|brown               |   |lt switch or dr kick        |
|       HEADLIGHTS|RED / yellow          |+  |at switch                   |
|     DOOR TRIGGER|BLACK/ blue          |+  |driver kick panel           |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|dk.GREEN/ purple     |-  |                            |
|       TACHOMETER|tan / YELLOW *3       |   |at coil                     |
|       BRAKE WIRE|lt. green           |+  |brake pedal switch          |
|     HORN TRIGGER|dk. blue            |-  |steering column             |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|red - yellow        |A  |in drivers door             |
|  RF WINDOW UP/DN|RED / blk - yel/blk   |A  |in drivers door or pkp      |
Notes:
*1 Negative trigger on the keyless-entry versions and 5-wire on all the rest.  *2 ESSENTIAL to use driver's switch when testing for switch and motor sides. The wires are much easier to access on the passenger side due to the E-brake blocking the drivers kick.      *3 Diesel tach is a WHITE/ pink and diesel wait to start wire is BLACK/ pink (-). Both wires are located at the PCM or the instrument cluster.
I would use a window module for the rear window and tie into the switch. There will be two wires that you will need to tap into to close the window with the system. I'm not sure which two wires they are but you will need to use a DMM to figure this out. The target wire will be (-) at rest and 12 volts when you press the button to close the window. This test the same if you want to open the window but the wire will be a different wire for the up direction.
