2001 honda civic, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102910
Printed Date: March 31, 2026 at 3:10 PM
Topic: 2001 honda civic, remote start
Posted By: 1caraudioman
Subject: 2001 honda civic, remote start
Date Posted: March 09, 2008 at 11:31 AM
i just put a remote start on my 2001 civic i used a die 556h so i did not have to buy another key everything works fine but when i start the car with the key the light on the dash that is in the shape of a key wont stop flashing any ideas? i have never used one of the 556h before.
Posted By: tedmond
Date Posted: March 09, 2008 at 5:37 PM
sounds like you didnt wire in your bypass properly OR it isnt programmed correctly. Place a key into the ignition, try to remote start. if it starts then its a bypass problem
Date Posted: March 09, 2008 at 7:10 PM
it starts fine with the bypass works great just when you start it with the key the keylight flashes but it still starts but the light never stops flashing????
Posted By: Velocity Motors
Date Posted: March 09, 2008 at 7:53 PM
Did you ground your key sense wire during remote start ?
------------- Jeff
Date Posted: March 09, 2008 at 8:04 PM
what wire is that i have a print out from code it does not say anything about it i cant get a dei sheet till i get to work in the morning?any help would be great still working on it thanks guys
Posted By: tedmond
Date Posted: March 09, 2008 at 9:48 PM
If i remember: Key Sense - RED / WHITE @ factory alarm plug. it might be at the ignition harness as well
Connect the RED / WHITE to Keysense wire from your bypass.
Date Posted: March 09, 2008 at 10:06 PM
the bypass dont have one. im just gonna buy a new key and do it the old way
Posted By: enice
Date Posted: March 09, 2008 at 11:18 PM
I had the same issue........i was told by DEI that the wire that the instructions menions that needs to cut need to be interrupted.....what you can do is just open that wire with a relay when remote started instead of cutting it and routing it through the bypass module...Im glad i wasn't the only one who had that issue...BTW i switched from the 556h to a honda sl3 and the light went away, Again....that same EXACT thing happened to me.
Date Posted: March 10, 2008 at 2:14 PM
sl3 who makes it
Posted By: enice
Date Posted: March 10, 2008 at 3:04 PM
Its made by fortin...its different wiring compared to the 556H but on the same harness. If I am not mistaken the honda sl3 would also be the same wirig as the trilogix modules(bypasskits.com).
Date Posted: March 10, 2008 at 5:28 PM
thanks did it work well?
Posted By: enice
Date Posted: March 10, 2008 at 6:51 PM
Yes it did. I have done a good share of civics and have had that issue come accross one of the civics. The other civics that I did worked flawlessly with the 556h but this one civic did not. It remote started but the "key light" kept flashing. I switched to the Honda SL3 for that vehicle and it worked perfectly too. Customers are happy. Personally I would use the Honda SL3. I always somehow had issues with the 556h for one reason or another. I always followed a "solid ground" and a "solid ignition, 12v". Honda SL3 programmed with a Acura TL while the 556h did not. Mind you.....THEY ARE COMPLETELY DIFFERENT WIRING...ie... different wires you need to tap into at the ignition
Posted By: tedmond
Date Posted: March 10, 2008 at 8:55 PM
Honda SL3 by fortin is probably the easiest bypass i have ever used. very simple hookup and very detailed explanation on the wiring with diagrams. I have used the DEI's bypass and i have had some trouble and the wire hookup is trciky for the first time installer. THe Fortin HONDA-SL3 goes for 40 bucks or so.
Date Posted: March 11, 2008 at 8:45 AM
anybody have one and do u you take paypal???
Posted By: tedmond
Date Posted: March 11, 2008 at 11:40 AM
where are you from, im sure an installer/member here on the forum is around your area, maybe they can even send u a unit and even wire it in for u too if you got some trouble.
Date Posted: March 11, 2008 at 12:59 PM
im in for smith ar install and have been for about 9 years i just dont have a way to get the fortin bypass only dei
Posted By: enice
Date Posted: March 12, 2008 at 11:06 AM
If you get DEI then get the bypasskit modules. They are part of DEI and im sure you can get the one specific for your Civic from bypasskits.com.....Just input the car info on the website and it will give you the model. That model is the same as the Honda SL3 so it should work the same. When you get the model just order it from DEI since thats what they use now.
Posted By: tedmond
Date Posted: March 12, 2008 at 3:56 PM
You can get the following
Bypasskits - PKH34 OR XK05 flashed with PHK3 Version: 2.00 iDataLink - TBSL HA Fortin - HONDA-SL3 they all work. the most costly would be idatalink, and bypasskits and fortin are roughly the same price.
