viper 791xv siren
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=102919
Printed Date: May 14, 2026 at 2:12 AM
Topic: viper 791xv siren
Posted By: texasfire06
Subject: viper 791xv siren
Date Posted: March 09, 2008 at 5:01 PM
I have a 100watt police siren speaker from my old gig. I have seen these types of sirens connected to the alarm. How do I do this? I have tried wiring it inplace of the stock viper/dei siren speaker. It didnt work
Posted By: tedmond
Date Posted: March 09, 2008 at 5:28 PM
im sure it uses more than 12volts.
Date Posted: March 09, 2008 at 6:27 PM
It is a driver. when you hook up 12 volts dc to it it clicks. If you were to hook up the leads from a car radio. it would play what the radio is dialed into. Police speakers are only that. SPEAKERS. The way police sirens work is by a seperate unit that makes the noise. I want to hook up my police speaker to my car alarm speaker. texasfire06
Posted By: howie ll
Date Posted: March 09, 2008 at 6:38 PM
You would hook up the driver circuits, brown from alarm to pos input, ground the neg then add the siren (speaker)
Posted By: howie ll
Date Posted: March 09, 2008 at 6:40 PM
Sorry I didn't explain properly. As it standsz its not compatible with the 791 Siren because this is a driver unit and siren, therefore you need the driver unit before it will work.
Posted By: Chris Luongo
Date Posted: March 09, 2008 at 6:44 PM
I've put in a couple of police sirens too. (In police cars, not in conjunction with an alarm.)
As you already know, the speaker is just a speaker. Not much different from a car or house speaker, except it's rugged and waterproof.
The other part of the system (that goes inside the police car) has a tone generator and amplifier....and is connected to the siren switches as well.
The typical car alarm siren has the tone generator, amplifier, and speaker all built into one housing. When you supply power on the red and black wires, it does its thing automatically.
You could disassemble the Viper siren, cut the wires from its internal speaker, extend them and connect them to your police-siren speaker........but I don't know if that's going to do much for you. You'll have a bigger speaker, but probably the amplifier inside the Viper siren isn't very powerful, and it's not going to be any louder than it was before.
If you really want the volume and sound of a police siren, you'd have to buy the rest of the parts to the system. Then, you could use the Viper's siren (or horn) output to trigger the aftermarket siren setup.
Here's a basic example of what you'd need:
https://www.lshlights.com/AMAZING/itemdesc.asp?Cartid={4E87C676-ED76-459A-9427-B2EVEREST585D147F4E}&ic=30%2E2106&eq=&Tp=
I believe the speaker is sold separately. You could use the speaker you already have instead of having to buy one.
Date Posted: March 10, 2008 at 12:10 AM
I have a siren driver/ amp. but how can I go about hooking this up. I mainly want the police siren to chip when I arm and disarm my alarm.
