grand cherokee brake light switch?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103000
Printed Date: May 13, 2026 at 5:28 AM
Topic: grand cherokee brake light switch?
Posted By: w87will
Subject: grand cherokee brake light switch?
Date Posted: March 12, 2008 at 12:22 PM
I have an 01 Grand Cherokee and I cant seem to get the brake light wiring harness out of the switch. Ive tried now for 2 days pulling up on it and it only comes up alittle bit. Anyone Know how to get it out or have a picture so I can atleast see what im doing? Thanks you.
Posted By: KarTuneMan
Date Posted: March 12, 2008 at 12:27 PM
Look for a WHITE/ tan in the drivers kick.
Posted By: w87will
Date Posted: March 12, 2008 at 1:19 PM
Ill give that a try. Hope it makes it easier :) Thanks for the quick reply. Im trying to get this thing done tonight.
Posted By: w87will
Date Posted: March 12, 2008 at 1:35 PM
I just looked at the kick panel. Found 2 boxes full of wires behind the trunk release. I unscrewed the Bottom box of wires and I see 2 WHITE/ tan wires.....one is a bigger gauge one is alittle smaller. Any ideas?
Posted By: Chris Luongo
Date Posted: March 12, 2008 at 1:43 PM
Turn the brake swith 1/8 of a turn to the left, and it pops out.
Be careful, as it is fragile.
Out of hundreds of Grand Cherokees, I've only had one brake switch go bad on me. I never really could figure out if it was already about to fail, or if I broke it. But it was only a #12 part at AutoZone.
Posted By: w87will
Date Posted: March 12, 2008 at 1:57 PM
Thanks Chris. It worked like a charm. After looking at it, Looks like its going to be the smaller gauge WHITE/ tan.
Date Posted: March 12, 2008 at 3:09 PM
You're welcome!
When you mention two different-gauge wires........hopefully you're testing all of your wires as you go along.
Hooking up to wires from a tech sheet without testing them can sometimes not turn out too well.
Posted By: tedmond
Date Posted: March 12, 2008 at 3:38 PM
no doubt ! fying the ECU or BCM isnt the best thing to do.
