2001 silverado requirements
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103015
Printed Date: May 13, 2026 at 9:38 AM
Topic: 2001 silverado requirements
Posted By: chrisneel
Subject: 2001 silverado requirements
Date Posted: March 12, 2008 at 10:40 PM
Hello, I'm getting ready to install an Autopage RS-1000 in my truck, a 2001 Silverado K1500.  I am just wondering if all I need is the alarm and a Passlock II bypass like the PLJX or GMBP?  If not what else will  I need?  Also, if that is all I need, which one would you guys recommend?  I've installed about 10 alarms/remote starts in the past, just none in a vehicle that requires any sort of bypassing...  Thanks in advance for all the help I'm sure I'll get!
Posted By: dtk1
Date Posted: March 12, 2008 at 10:51 PM
it has passlock II make sure to power up the second ignition (white wire)to avoid the check engine light GMBP would be perfect for this car. door locks are at the bcm under driver side dash have fun.
