2007 kia rondo ex 4cyl
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103045
Printed Date: May 13, 2026 at 2:43 PM
Topic: 2007 kia rondo ex 4cyl
Posted By: mpd671
Subject: 2007 kia rondo ex 4cyl
Date Posted: March 13, 2008 at 9:20 PM
OK - I guess I've got a rare one here.
Bought this car today, so looking into installing a remote start.  I'd have to call myself a novice.
Looking for wiring diagrams and vehicle specific hints.
Also looking for info / resources on buying and programming a couple of spare transponder keys.  Any research I'v edone so far makes mention of needing a dealer's tool to program these (and OEM remotes).  Even info on keyless bypass kits seem to require dealer tool programming.
Optimally I want to install a starter that will also replace OEM Keyless entry fob, rear hatch release.  Window rollup would be nice, especially to close the moonroof.
Thanks much
Bill in Bethlehem, PA
Posted By: dtk1
Date Posted: March 13, 2008 at 9:56 PM
MODEL       YEAR(S)
RONDO       2007 -
KEY       T-HARNESS       IMMOBILIZER
N/A       N/A       Transponder Anti-theft requires 791 and extra ignition key (SOME MODELS)
PART       COLOR       LOCATION       DIAGRAM
12 VOLT CONSTANT       BLACK (+) OR RED (+) IGNITION SWITCH HARNESS
STARTER       BLACK / YELLOW (+)       IGNITION SWITCH HARNESS
STARTER 2       N/A       N/A
IGNITION 1       WHITE/ BLUE (+)       IGNITION SWITCH HARNESS
IGNITION 2       WHITE (+)       IGNITION SWITCH HARNESS
IGNITION 3       N/A       N/A
ACCESSORY /HEATER BLOWER 1       GREEN (+)       IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2       N/A       N/A
KEYSENSE       N/A       N/A
PARKING LIGHTS ( - )       N/A       N/A
PARKING LIGHTS ( + )       GREEN/ ORANGE (+)       LOW IN DRIVERS KICK PANEL
POWER LOCK       WHITE (-) TYPE       IN DRIVERS KICK PANEL
POWER UNLOCK       WHITE/ BLACK (-) TYPE       IN DRIVERS KICK PANEL
LOCK MOTOR WIRE       N/A       N/A
DOOR TRIGGER       BROWN (-)       IN DRIVERS KICK PANEL
DOMELIGHT SUPERVISION       USE DOOR TRIGGER       IN DRIVERS KICK PANEL
TRUNK RELEASE       N/A       N/A
SLIDING POWER DOOR       N/A       N/A
HORN       YELLOW/BLACK (-)       STEERING COLUMN HARNESS
TACH       N/A       N/A
WAIT TO START LIGHT       N/A       N/A
BRAKE       GREEN (+)       AT SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM       N/A       N/A
ANTI-THEFT       TRANSPONDER ANTI-THEFT       TRANSPONDER @ IGNITION SWITCH TUMBLER
Posted By: KarTuneMan
Date Posted: March 14, 2008 at 3:10 PM
Pulse the drivers door pin after runtime to shut down the retained accs. power.
door pin is grey @ BCM, top plug. Tach is in the drivers kick in a blue plug, it's a white wire.
The locks are unique on this car, so test carefully. There is a lock, and an unlock. BUT there is also a lock/arm, and unlock/disarm, WITH a key posistion wire.
You will need a relay to "break" the yellow key position wire. PM me if you get stuck, I will TRY and describe to you how to wire this up.
