Keyless Entry Needs Hooked Up
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10306
Printed Date: April 18, 2026 at 10:01 PM
Topic: Keyless Entry Needs Hooked Up
Posted By: moparfreak77
Subject: Keyless Entry Needs Hooked Up
Date Posted: March 02, 2003 at 11:44 AM
I own a '95 Jeep Cherokee Country with factory keyless entry. I bought a Prostart Model No. CT3300 and I have the auto starter hooked up but not the keyless entry. It is a pain to have the starter remote and the factory keyless one. I believe my door locks are negative fed? Do I need relays to make this all work? Thanks
Posted By: securinu
Date Posted: March 02, 2003 at 11:54 AM
lock = ORANGE / purple ( + )
unlock= pink/purple ( + )
both in driver kick panel yes you will need relays.
follow this diagram
https://www.the12volt.com/doorlocks/page3.asp#3wp
Date Posted: March 04, 2003 at 5:41 PM
I know the basics of wiring but know nothing about relays. What do I need to know to buy these?
Posted By: Velocity Motors
Date Posted: March 04, 2003 at 9:31 PM
The Jeep uses a (+) type trigger for it's door lock system. Unless your Prostart has alternating polarity door locks, you will require the use of the relays to convert the (-) signal to a (+) one that the door locks can use.
------------- Jeff
Date Posted: March 05, 2003 at 12:31 PM
Go to your local auto parts shop or electroni store & ask for 2 30/40 amp SPDT relays. First off, make sure that the Prostart only has (-) trigger door lock wires . If it has (+) & (-) door lock wires then you do not need the relays.
------------- Jeff
Date Posted: March 05, 2003 at 9:25 PM
Thanks a lot for the help guys. I'll do that and let you know how I make out.
