04 sentra clutch bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103127
Printed Date: April 18, 2026 at 1:54 PM
Topic: 04 sentra clutch bypass
Posted By: talktotravis
Subject: 04 sentra clutch bypass
Date Posted: March 16, 2008 at 11:48 PM
Hello,
I have a 2004 Nissan Sentra with the 1.8/QG engine. I'm installing a Compustar remote start (the MT manual) and I'm not quite sure how to go about bypassing the clutch with a relay. I know that I need to access the switch at the base of the clutch (as opposed to the first one that breaks cruise control). Does anyone know to do this? I'm not sure if I need a relay or if this system requires a (-) signal. Thanks in advance.
Date Posted: March 16, 2008 at 11:53 PM
I just found out that this is a "Type 2" system, where my clutch wire needs to see ground. If the Compustar outputs a 500ma or so signal, will this be sufficient or is a relay needed? Any and all insight that you could give me would be appreciated.
Posted By: KarTuneMan
Date Posted: March 17, 2008 at 9:49 AM
A relay to trigger a relay. Nope, hook up a negative start to the BLACK/ red @ the clutch switch.
Date Posted: March 18, 2008 at 2:19 PM
Thank you KarTuneMan. You've helped me in the past and I appreciate it, as always.
