Problem With Alarm Door lock
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=1034
Printed Date: March 31, 2026 at 10:04 PM
Topic: Problem With Alarm Door lock
Posted By: i4u2cravei
Subject: Problem With Alarm Door lock
Date Posted: May 30, 2002 at 8:21 AM
Need some advise on power door locks on a 1996 town and country minivan i got it lock part too work with a 1.5 ohm Resistor  on the alarm but i cant get the unlock too work i even use the 249ohm Resistor but i wanna know if  the ground is not enought and if i need too use any relays to step up the ground please email me back if any can
Posted By: Big Dog
Date Posted: May 30, 2002 at 9:20 AM
Hey i4u2cravei,
The selected resistor values are correct if you don't have a factory alarm on this van.  If there is an alarm then it's a 4020 ohm for lock and a 665 for unlock.  In either case you MUST USE RELAYS for lock and unlock.  An alarm module sends a negative pulse through transistors but it's not a true ground pulse.  posted_image
Prepare your future. It wasn't the lack of stones that killed the stone age.
