2007 f150, avital 400xl, imo4 bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103501
Printed Date: May 13, 2026 at 6:24 PM
Topic: 2007 f150, avital 400xl, imo4 bypass
Posted By: mthake
Subject: 2007 f150, avital 400xl, imo4 bypass
Date Posted: March 29, 2008 at 5:03 PM
I need some help here if you don't mind. I have installed this entire system on my truck. Everything works good if I have the Key in the ignition. I know its a problem with the bypass, but can't figure it out. I have the green wire going to GREEN / WHITE and pink wire going to the gray/orange. red to constant power, black to ground. The ground when running, I had hooked up to a -200ma from the rs. I did the program step 1 of the instructions and the imo4 says its programed. it is also flashing the led in sequence with the security led. It all seems to be hooked up correctly, but it will only remote start with the key in the ignition. Any help would be appreciated.
thanks
Posted By: mthake
Date Posted: March 29, 2008 at 5:54 PM
nevermind, got it going, had to program with 2 keys and she started right up.
