cifford 50.5x sensor layout am i correct?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103517
Printed Date: May 13, 2026 at 5:13 PM
Topic: cifford 50.5x sensor layout am i correct?
Posted By: mrcllusb
Subject: cifford 50.5x sensor layout am i correct?
Date Posted: March 30, 2008 at 5:15 AM
Okay on the 50.5x that i am installing on my Milan it has a shock sensor port,violet(+)door trigger input,blue(-)trunk trigger input,green(-)door trigger input and gray(-)hoodpin shutdown input.The extras i'm going to use are a radar sensor(au94t),tilt sensor(507M),and a battery backup(520T).I'm not using the shock sensor that comes with it.My Milan has (+)door trigger/dome supervision which dei says to just use the dome super wire.So that leaves me with the (-) door trigger,trunk trigger,and hood trigger.I've drawn up my layout as such,
AU94T-plug into shock sensor port(just have to reverse blue and green on sensor side plug as crimeguard is opposite of dei.)
507M-Blue(-)trigger from here to Green(-)trigger since not being used.
520T-Blue from here to Gray(-)hoodpin wire,(Diode isolated)since this will also be feed from my hoodpin.I will do a Y diode setup so that one end is the hood wire and the other the 520T trigger wire going into one wire(gray wire from alarm) with bands facing the sensor sides.
------------- "ole blake"
Posted By: mrcllusb
Date Posted: March 31, 2008 at 1:16 PM
Can anyone confirm this layout for me?
