94 grand cherokee, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103571
Printed Date: April 01, 2026 at 5:13 PM
Topic: 94 grand cherokee, remote start
Posted By: hayes48
Subject: 94 grand cherokee, remote start
Date Posted: March 31, 2008 at 10:40 PM
I hooked up a remote start in my 1994 Grand Cherokee and everything works fine except  after i remote start it and then i put the key in the run position the remote start does not recognise the key and will still die out if i hit the brake it make me turn off the remote starter manually by pressing the star button twice(same way as turning it on) even though the key is in the on possition if anyone has any info that can help me it would be greatly appreciated
Posted By: dtk1
Date Posted: March 31, 2008 at 10:51 PM
chek all you wires with the KEY. make sure ignition is getting +12v acc is getting +12v there maight be a chance that you silece a wire and is not gettina good conection when you start with the key or do a key takeover
Posted By: techman93
Date Posted: April 01, 2008 at 12:30 AM
you might have split an ignition through an anti-grind circuit. Make sure your connections are correct.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Posted By: Chris Luongo
Date Posted: April 01, 2008 at 7:15 AM
Any chance you're not turning the key far enough forward?
Date Posted: April 01, 2008 at 7:32 PM
Like your are turning it to acc not to run which is one more notch forward.
Posted By: hayes48
Date Posted: April 01, 2008 at 7:44 PM
i know it is in the run possition for a fact
Posted By: hayes48
Date Posted: April 01, 2008 at 7:54 PM
If i only have one ignition in my car, i dont need to use ig2 right? and if i dont use ignition 2 do i need to use the red and white 12v connection? and if i use the red and white 12v and do not have ig2 hooked up will it cause a problem?
Date Posted: April 01, 2008 at 9:39 PM
if it requires two ignitions that might be the issue but you are having problem with key take over, not starting vehicle. You can always just hook it up and see what happens.
