ford focus 530t module wiring?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103590
Printed Date: April 01, 2026 at 8:21 PM
Topic: ford focus 530t module wiring?
Posted By: wungun
Subject: ford focus 530t module wiring?
Date Posted: April 01, 2008 at 10:50 AM
I have a couple of questions...
For the motor wiring of both driver and passenger doors, this can all be hooked up after the drivers 'master' window switches in the drivers door only, correct?
I don't have to run the motor wires from the 530 to both doors I'm assuming....
For the one touch feature for both driver and passenger, I HAVE to run the switch wires into both doors, right?
My drivers side has a factory one-touch down feature...I should hook the module up on the motor side AFTER the module?
And finally, I have to cut the wires from the OEM switches on the motor side for both up and down?
Posted By: howie ll
Date Posted: April 01, 2008 at 11:27 AM
You've asked and CORRECTLY answered all those questions. Congratulations;  sorry for sounding sarcastic but it's nice to see someone working out the right answers themselves and just asking verification, it's nice to see, NB On the UK Focuses you have spare grommets on the bodywork facing the front doors, use 1 each side to get from car to door and 1 on l/h/side to work through wheel arch into engine bay, it will save you drilling the bulkhead.
Posted By: howie ll
Date Posted: April 01, 2008 at 11:34 AM
Sorry just reading it again, I'm afraid for the diver and passenger side you have to go into each door and go between switch and motor.
Posted By: wungun
Date Posted: April 01, 2008 at 12:32 PM
Oh...I can't send power to the passenger motor from the drivers side passenger switch?
Posted By: howie ll
Date Posted: April 01, 2008 at 12:44 PM
Unfortunately no, you will loose 1 touch up/down on the passenger window.
Posted By: wungun
Date Posted: April 01, 2008 at 11:02 PM
I mean, if I hook up the switch side of the 530T to the passenger switch, but instead of running the motor power wires
into the passenger door, hook them to the drivers side passenger switch, it should work okay, correct?
Posted By: wungun
Date Posted: April 03, 2008 at 7:51 AM
That's what I gathered from the wiring diagram at least...
Posted By: OmarR
Date Posted: April 29, 2008 at 1:55 AM
You will have to run the switch wires and the motor wires to the passenger side.
Posted By: danielboston
Date Posted: July 09, 2008 at 6:33 AM
hello there i need some help with 2 530t  ,question is when get one 530 t connected to the  remote starter ,do i have to repeat same installation for the other one?,i mean im using one 530 for one front door and one back door  right side and the other front and left door another 530t  im talking about the small gauge wires , cause maybe i need to bring them to the drivers side  right? also the gray wire do i need  to connect it?or not? thanks
