Difference Between a 1 Way and 2 Way Remote Starter?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103754
Printed Date: April 01, 2026 at 3:16 PM
Topic: Difference Between a 1 Way and 2 Way Remote Starter?
Posted By: ratmkicksass
Subject: Difference Between a 1 Way and 2 Way Remote Starter?
Date Posted: April 05, 2008 at 9:10 PM
K I tried looking everywhere but did not find my answer so here it is, first of all, whats the difference between a 1way and 2way remote starter? Second one is that Im going to install it on a 99 4runner and dont want to spend too much on it... I found some 4 like 80 bucks, which is nice, and then there are some 4 like 400.... I just want it to be practical... Thanks...
Date Posted: April 05, 2008 at 9:16 PM
sorry I forgot to mention that I am also gonna get it with alarm...
Posted By: techman93
Date Posted: April 06, 2008 at 12:13 AM
1 way means you push button on transmitter to lock/unlock and receiver gets signal and then does what it is supposed to do, if it is within reception range.
A 2 way means the same as a 1 way but it will also transmit a signal back to the transmitter indicating it received command and the command was carried out, if it is within operating range that is.
If it is a combo unit I would at least buy a reliable unit in the $200 range if your doing it yourself. If your going to have it put in at least plan on $300 - $400 completely installed.
------------- The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
