04 dodge 2500 with cummins
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=103858
Printed Date: March 31, 2026 at 1:29 PM
Topic: 04 dodge 2500 with cummins
Posted By: eng1
Subject: 04 dodge 2500 with cummins
Date Posted: April 09, 2008 at 12:57 PM
was going to install avital 4200 in this veh. has auto trans cummins and a black keyhead. can i just put the remote start in or do i need to bypas anything also any wire diagrams thanks for the help
Posted By: brcidd
Date Posted: April 09, 2008 at 2:38 PM
Better check the blower motor amps- Last one I did pulled two many amps through the brain box- and melted a hole in the box without blowing the fuse- I recommend an external relay for the blower motor- since Dodge does NOT use a hi speed relay like most other cars. Technical assist actually told me to tell the owner not to set the blower switch on high speed-- yeah right.....do some searches for '04 Rams on this site......
------------- Brcidd - Engineer That Does Remote Starter Installs on the side.
Posted By: KarTuneMan
Date Posted: April 09, 2008 at 10:04 PM
Power up the second ign. (pink/white next to the big red 12v) first. Use a relay and trigger it with ground while running. No issues.
