audi a5 immobilisation point.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104002
Printed Date: March 31, 2026 at 12:40 AM
Topic: audi a5 immobilisation point.
Posted By: norbert.s.
Subject: audi a5 immobilisation point.
Date Posted: April 15, 2008 at 11:54 AM
I need immobilisation point in Audi A5 2.7 turbodiesel, no starter but engine, fuel pomp...
Posted By: howie ll
Date Posted: April 15, 2008 at 3:34 PM
Ign feed, should be BLACK/ blue or same wire going to dashboard fusebox. Be careful this beast is heavy on CAN systems.
Posted By: skee-weezy
Date Posted: April 16, 2008 at 8:57 AM
there should be a transponder based immobilizer already on your car... not worth the time and frustration to wire a secondary kill.... after all..this is an audi we are talking about...  a thief ain't gonna show up with a slim jim and a flathead screwdriver hopin to take it for a spin... THEY ARE GONNA BRING A TOW TRUCK... then once in the quiet confines of the thief's chop shop...they will very calmy disable that secondary kill if the goal is to drive the thing... but they will also have to hack the bcm and bypass the transponder system... not an easy task... DUDE... PAY YOUR INSURANCE..... forget about the kill..it ain't worth it..not to mention if it malfunctions not even u will be able to start your car....
there can be only one.......
Date Posted: April 16, 2008 at 10:42 AM
Thanks howie ll.
Are you sure? Black-blue wire in black 18-pin connector ? {pos.nr 1}
Posted By: howie ll
Date Posted: April 16, 2008 at 1:25 PM
I'm actually with skee-weezy on this, unless you know exactly which BLACK/ blue to go for leave well alone. They are a bundle of (very expensive) electronic systems problems to the uninitiated.
