689m bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104462
Printed Date: May 11, 2026 at 11:21 AM
Topic: 689m bypass
Posted By: pitoaudiovisual
Subject: 689m bypass
Date Posted: May 03, 2008 at 9:14 PM
I tryed to install a remote start unit into an 03 acura RSX and its manuel. DEI told me to use a 689M but i have never installed it before and tryed to make it work and it wasnt working. I need info on what wire to connect to what to see if i installed it right . I found the emergency wire and the brake pedal but there is a wire that says something like light blue wire remote wire input negative. Do i need to connect the neutral wire of the tranny or something. any help is very useful. Maybe the bypass has to be trained.
Confidence is the key to any project!!
Posted By: tedmond
Date Posted: May 05, 2008 at 2:56 PM
the 689m is not the easiest unit to install. If you can rescan me a copy of that manual, i can show you what wires to splice into on the car.
Posted By: Big Dog
Date Posted: May 05, 2008 at 3:08 PM
Here's the 689M manual.
The light blue is a negative shutdown input used generally to connect to a motion sensor which would disable the remote start sequence should someone enter the vehicle.
You don't really need this so just disregard (make sure it doesn't touch ground).
Also, make sure that the BLACK/ white of the 689M goes straight to BLACK/ white of remote starter (if using a DEI remote starter) and no where else.
I've done so many, I can do this module with my eyes closed, both hands tied behind my back and wearing a body cast.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Posted By: KarTuneMan
Date Posted: May 05, 2008 at 6:27 PM
I myself would pay any amount of money to see this.......posted_image
Posted By: Big Dog
Date Posted: May 06, 2008 at 7:12 AM
I skin the wires with my teeth posted_image
Posted By: tedmond
Date Posted: May 06, 2008 at 2:15 PM
no doubt ktm. I would like to see it done.  key big dog, can you skin and wrap the wire with your teeth ? ahah
