2006 caravan radio power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104465
Printed Date: May 11, 2026 at 12:23 PM
Topic: 2006 caravan radio power
Posted By: plumber_ken
Subject: 2006 caravan radio power
Date Posted: May 03, 2008 at 10:52 PM
Can some1 tell me the colour of the 12v switched wire that goes to the radio..im am trying to install interior led lighting and it calls for it ..and im not sure which colour it is.
please help.
ken
Posted By: Chris Luongo
Date Posted: May 04, 2008 at 9:46 AM
I don't believe there's any switched power available behind the radio. I'm pretty sure the radio on/off is controlled by the car's computer system.
But you could try the two cigarette lighter sockets down there near the cupholder.
If I remember right, one of those switches on and off with the key, and the other one, you can choose constant or switched by moving a fuse under the hood.
Posted By: ceasar326
Date Posted: May 04, 2008 at 1:54 PM
you can try using the ignition wire its more safe
pink/white (+) (20 Gauge) (2 Wires, use either wire)
Location  Ingnition switch hardness, Black Plug
Posted By: chriswallace187
Date Posted: May 04, 2008 at 5:24 PM
I would steer clear of the ignition unless you could verify that the LED lights don't draw serious current through that switched wire - most kits I've seen do, and the ignition switch on that car can't support much extra current draw.
Switched lighter outlet should be fine in that regard.
C Renner's Auto Electronix
Date Posted: May 04, 2008 at 6:11 PM
thanx i wired them the lighter...and they r lonly 4 lil led diodes..dont think they draw much pwer at all...thanks all!!!
