2002 honda stream wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104566
Printed Date: April 19, 2026 at 5:22 AM
Topic: 2002 honda stream wiring diagram
Posted By: nmvong
Subject: 2002 honda stream wiring diagram
Date Posted: May 08, 2008 at 2:27 AM
Hi, I need wiring diagram for Honda Stream 2002 model to install my car alarm. Appreciate anyone who can tell me where I can get a copy. Thanks.
VNM
Posted By: chriswallace187
Date Posted: May 08, 2008 at 6:15 AM
You might have trouble finding that info on here, however you could use the "vehicle wiring" search on this site to find info on the '01-'05 Civic which would probably be similar to your car. Obviously you'll need to verify the wires with a DMM.
C Renner's Auto Electronix
Posted By: tedmond
Date Posted: May 08, 2008 at 2:14 PM
kinda looks like an 07 civiv OR an acura tsx.
Posted By: howie ll
Date Posted: May 08, 2008 at 4:38 PM
Look for the factory security module, it's white and in UK Civics it's mounted to right of steering column. If you pull the plug and the car still starts, then find out what each wire does, e.g. door, trunk and hood contacts, indicators (hazards) ign stand off, power and ground lock and unlock are all going into it.       Just join in to it.
Posted By: nmvong
Date Posted: May 16, 2008 at 1:24 AM
Thanks all for your help.
VNM
