viper 571xv and by passing clutch switch
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104594
Printed Date: May 11, 2026 at 10:05 AM
Topic: viper 571xv and by passing clutch switch
Posted By: katit
Subject: viper 571xv and by passing clutch switch
Date Posted: May 09, 2008 at 10:30 AM
Hi!
I'm doing install on manual car. I have neutral switch in a car so it won't be an issue.
I need to by-pass clutch switch but I can't find appropriate lead coming from Viper to use.
What is a common solution for that? Please don't tell me about safety. I know, I know. I took precautions. I just need to know how to get around clutch with this specific remote model.
Thanks!
Posted By: KarTuneMan
Date Posted: May 09, 2008 at 11:21 AM
A DEI 689m is the solution.
AND you will want to scan the forum rules as well. You can talk about how safe you have been.... it's still against the rules to ask how to do it without the proper parts.
Read this post.
Posted By: katit
Date Posted: May 09, 2008 at 11:25 AM
Got it posted_image
By reading 689M install manual I figured which wire I need..
Thanks!
Date Posted: May 09, 2008 at 11:26 AM
Cool! posted_image
