viper 690xv wont arm and disarm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104598
Printed Date: May 11, 2026 at 6:25 AM
Topic: viper 690xv wont arm and disarm
Posted By: tak4
Subject: viper 690xv wont arm and disarm
Date Posted: May 09, 2008 at 1:46 PM
Hello,
I have a Viper 690XV and after working on my car one day, the alarm wont arm or disarm. There is a box looking think with a few wires coming out of it thats hanging down, that looks like it was screwed in someplace. could that be it?
I also read on google, to unplug the brain, and reprogram the remote. but i cant my manual and cant find a online guide to reprogram it.
any help?
Posted By: tak4
Date Posted: May 09, 2008 at 1:53 PM
I checked the website and downloaded a manual but it doesnt seem to tell me how to re program it
Posted By: fcss
Date Posted: May 09, 2008 at 2:56 PM
do the doors lock and unlock without chirps or nothing at all
Posted By: tak4
Date Posted: May 12, 2008 at 5:35 PM
For some time now, my viper 690XV has been having no signal. I would unlock or lock it and it would just beep 6 times.
I read that i should disconnect and reconnect the brain, and reprogram the remote. i did that but since my remote has no signal i cant reprogram it.
There is a harness looking thing that i think is suppose to be screwed someplace but idk where. should i screw it to a ground?
posted_image
Posted By: cmk0808ny
Date Posted: May 12, 2008 at 5:52 PM
zip tie it out of the way of things
Posted By: tak4
Date Posted: May 12, 2008 at 6:02 PM
so it doesnt go anywhere? I thought that might be the problem.
Any way to fix the no signal problem?
Date Posted: May 12, 2008 at 7:35 PM
unplug the antenna for a few mins and then reconnect. reprogram the remote. should be good after that.
Posted By: tak4
Date Posted: May 12, 2008 at 8:02 PM
ok ill try that now
Posted By: tak4
Date Posted: May 12, 2008 at 8:21 PM
its still not working, any other reason why it wont work?
Posted By: techman93
Date Posted: May 13, 2008 at 7:57 PM
Had you replaced the transmitter battery?
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Posted By: tak4
Date Posted: May 14, 2008 at 1:59 AM
the transmitter as in the remote? or the antenna? I did change the remote battery. and still nothing
Date Posted: May 14, 2008 at 10:36 PM
Ummm... yes transmitter is remote obviously.
Have you tested for 12v+ and ground to be sure the unit has power?
Have you made sure the harness is securely plugged into module and it is on the correct way?
Did you check all the fuses that attach to the unit and in the car fusebox?
Is the antenna one that plugs in, if so is it plugged into brain correctly? That could be one reason for unresponsive unit.
If the unit is getting power and the antenna is plugged in, there might be an issue with the module.
