dei doorlock module
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10474
Printed Date: May 16, 2026 at 6:30 AM
Topic: dei doorlock module
Posted By: kcalvert
Subject: dei doorlock module
Date Posted: March 05, 2003 at 2:04 PM
anyone ever hooked up the dei doorlock module in a 99 neon, i believe this is a 5 wire system, not sure how to hook it up. can anyone help
Posted By: auex
Date Posted: March 05, 2003 at 3:27 PM
It is easy. Find your lock and unlock wires and cut them in a place you can connect other wires to them. First the purple wire goes to +12v then the green wire goes to the motor side of the lock wire(ORANGE / purple) then the white wire goes to the switch side of the same wire. Then take the blue wire and connect it to the motor side of the unlock wire(pink/purple) and then connect the brown wire to the switch side of the wire. The small three pin plug will plug into a dei brain. If you are using a non dei alarm then hook the small green to the lock output of the alarm and the blue to the unlock of the alarm. The small gauge red will go to the opposite polarity of the alarms output for the locks(if the alarm supplies a negative output then it would goto power)
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
