viper 560xv issues
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104806
Printed Date: May 13, 2026 at 1:01 AM
Topic: viper 560xv issues
Posted By: yoheidiho
Subject: viper 560xv issues
Date Posted: May 17, 2008 at 7:37 PM
I recently had a Viper 560XV installed in my wife's 2005 Camry LE. Since the install we have had issues. The alarm has acted up it has caused no start conditions. It has also caused the 5A ECU–ACC fuse to burn out.
A particular issue is the remote start starts the Camry but the but the engine will die with the key in the ignition in the on position upon application of the brakes. Combination meter, radio and clock display work fine while engine is running. Upon restarting with the key, no combination meter, radio or clock display (burnt fuse).
Anyone know why the circuits on the 5A ECU–ACC are operation during remote start warm-up but not during manual start? It seems to me that the circuits should be dead since the fuse is blown.
Had the brain removed for a few days without any problems. Had it reinstalled and issues resurfaced again after just six days. Now the brain and harnesses are out of the car.
It appears to be either the brain or the installation. It is a reputable shop that has done well be me over the years.
I tried reachind out to DEI but they told me to deal with the dealer. I suspect the dealer has little if any troubleshooting skills.
Any help/insight is appreciated.
Posted By: KarTuneMan
Date Posted: May 17, 2008 at 8:14 PM
This is an EASY car. I am shocked first, that you have the problem, second, that they cannot find and fix it! Have you asked them to remove it and give you a refund? They owe you that if they are going to stand there with their hands in the air with a stupid look on their face. Have they reinstalled a new, and different unit yet? -------------
Date Posted: May 18, 2008 at 8:43 PM
The refund shouldn't be a problem. They want to keep the brain out for a couple of weeks to see if the fuse burns out again. I don't think it will. If it was the brain then reinstalling the same one will give me the same issues. It it was the install, then a new install should fix the issue. Since they don't seem to have a way to test the brain I am not sure I want to have the same brain reinstalled.
Posted By: JWorm
Date Posted: May 18, 2008 at 9:35 PM
Wiring for that car...
12 Volts WHITE/ red (30A), white (5A) + ignition harness
Starter BLACK/ white + ignition harness
Second Starter BLACK / YELLOW + ignition harness
Ignition BLACK/ red + ignition harness
Second Ignition BLACK / YELLOW + ignition harness
Accessory blue/red + ignition harness
The dealer probably connected one of the power wires from the 560xv to the white (5 amp) constant wire at the ignition harness. That is the problem. They should not be using that wire. Have them connect all power wires from the 560xv to the WHITE/ Red wire at the ignition harness, or run them to the battery. I always did those cars by connecting all power wires to the WHITE/ red. One time I had to take a trip to a customers house when a co-worker connected one of the constant wires to the 5 amp constant wire and blew the fuse. Replaced the fuse, rewired it correctly and the problem never happened again.
Posted By: zigger215
Date Posted: May 21, 2008 at 2:27 AM
i have a theory however Jworm is probably right because i have seen that before, the other thing is a broken solder joint, provided that they even solder. if the wire i broken then it would work with the auto start but not the key because the connection is broken especially if it were an ignition wire, the likely hood in this theory is minimal compared to Jworms however.
------------- "so should that little computer under the dash smell burnt? I DIDN"T DO IT!"
