buick lesabre
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=10488
Printed Date: May 16, 2026 at 12:58 AM
Topic: buick lesabre
Posted By: mament
Subject: buick lesabre
Date Posted: January 30, 2003 at 7:09 AM
hi i am having trouble with hooking up a remote starter to a buick lesabre. everything is hooked up and we did everything the video and instructions said but we cant get the car to start. can you show me a wiring harness for this car?
Posted By: 2quic
Date Posted: January 30, 2003 at 4:47 PM
| 2000 Buick LeSabre Security Information | | 12V | Red | Ignition Switch | | Starter | Yellow | Ignition Switch | | Ignition 1 | Pink | Ignition Switch | | Ignition 2 | NA | NA | | HVAC 1 | Orange | Ignition Switch | | HVAC 2 | NA | NA | | Accessory | Brown | Ignition Switch | | VATS | Inside Orange Sheathing | Ignition Switch | | Hot Side Brake | Orange | At Brake Switch | | Cold Side Brake | White | At Brake Switch | | Tach | White | At Coil | | Lock | RED / Black | Left Door Jamb | | Lock Type | 3 wire negative | | Unlock | ORANGE / Black | Left Door Jamb | | Unlock Type | 3 wire negative | | Trunk Release | Black | In drivers door | | Trunk Release Type | Negative | | Head Lamp | Yellow | At Switch | | Head Lamp Type | Positive | | Park Lamp | Brown | Left Kick Panel | | Park Lamp Type | Positive | | Door 1 | Gray/Black | Left Door Jamb | | Door 1 Type | Negative | | Door 2 | Gray | Rear Pin Switch | | Door 2 Type | Negative | | Door 3 | NA | NA | | Door 3 Type | NA | | Trunk Pin | ORANGE / Black | At Trunk Light | | Trunk Pin Type | Negative | | Horn | Black | Steering Column | | Horn Type | Negative | | OEM Arm | NA | NA | | OEM Arm Type | NA | | OEM Disarm | Light Green | Left Kick Panel | | OEM Disarm Type | Negative | | Sense | Tan | In drivers door | | Sense Type | Positive | | LF Window Up | NA | | | LF Window Down | NA | | | RF Window Up | NA | | | RF Window Down | NA | | | LR Window Up | NA | | | LR Window Down | NA | | | RR Window Up | NA | | | RR Window Down | NA | | | Window Location | | At Drivers Window Switch | | Windows Type | NA | | Notes | For keyless entry upgrade to an alarm, Arm = Gray (+), Disarm = Tan(+), both located in left kick panel or left door jamb, Sense = same as above. |
------------- pony e-x-press
