08 dodge charger wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=104921
Printed Date: May 13, 2026 at 3:34 AM
Topic: 08 dodge charger wiring diagram
Posted By: mrcllusb
Subject: 08 dodge charger wiring diagram
Date Posted: May 22, 2008 at 12:20 PM
Does anyone have this diagram?
"ole blake"
Posted By: hydroz_23
Date Posted: May 22, 2008 at 10:54 PM
same as 07 except for ignition is quite a bit different. you will need to remove ignition, remove circuit board and solder 3 to 4 wires to the board. you can use a xk06 for rs, xko7 for locks and a pku-ch2 for transponder. or the best way is idatalink. i have done 2 dozen of the new chryslers the idatalink is the way to go. there are several threads on doing the new chryslers
