domelight/interior light delay
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105147
Printed Date: May 06, 2026 at 1:37 AM
Topic: domelight/interior light delay
Posted By: spaspecker
Subject: domelight/interior light delay
Date Posted: May 31, 2008 at 11:13 AM
I want to use this relay diagram (momentary to constant) to activate my domelight when I unlock my car. How do I wire it to switch off the domelight when my ignition key is turned? I can feed the relay a negative pulse from my OEM central locking relay, BTW I have neg doorpins
Posted By: albertatech
Date Posted: May 31, 2008 at 11:20 AM
run a relay off the starter wire , fuse protect and diode isolate it to prevent issues. Run ground to the common and ground out to your relays out of normally closed. When the Starter power hits the relay and activates (opens) it the dome will terminate. The relay will then shutdown after cranking.
Date Posted: May 31, 2008 at 11:23 AM
NOTE: if you run the relay off of IGN power it would also work but the relay would remain active until the key was shut off and although it would probably be okay, it could potentially cause issues with the relay by being on all the time. If you do it that way take into consideration the quality of the relay, the load capacity, and the fact its not a good idea imo.
Date Posted: May 31, 2008 at 2:46 PM
thanks for your input - any other suggestions?
Date Posted: May 31, 2008 at 3:52 PM
Not atm, sounds like a interesting project though, Good luck :)
