bmw 645ci
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105419
Printed Date: April 06, 2026 at 8:26 AM
Topic: bmw 645ci
Posted By: slicksam
Subject: bmw 645ci
Date Posted: June 11, 2008 at 9:02 PM
A friend of mine bought a 2005 BMW 645ci. He asked me to install a remote starter. My question is can it be done? Is this car DATA? If it is possible I guess I have to take a key off him for the transponder? I would need to see the wiring information on this car. ------------- Testing is the key
Posted By: KarTuneMan
Date Posted: June 12, 2008 at 12:26 AM
Talk to Howie !
Posted By: howie ll
Date Posted: June 12, 2008 at 11:30 AM
What's the key? Is it a regular of slot type?
Posted By: enice
Date Posted: June 12, 2008 at 8:39 PM
If I'm not mistaken the 2006-up vehicles have the new body styles and Fortin may make a bypass module for it. If I were you I would look more in detail to a wiring diagram from www.eautorepair.net Purchase the diagram for 10 bucks a week and it will give you info on what you are getting involved in. That website belongs to mitchell and is for a do it yourself'er. The actual mitchell program is used by Directed Electronics and is about 250 a month. I've used it and it has saved me a bunch
Posted By: slicksam
Date Posted: June 14, 2008 at 4:43 PM
I got to see the car, it is a regular key(transponder look) according to bypass's for this car fortin have one, looks like alot of brake connection. https://ifar.ca/download.php?productmanualid=713&key=3fe40c724fae7b5ff40803a3d2efc4c5 as for the main wires?....should be all at the ignition, should i attempt this car??? ------------- Testing is the key
Posted By: enice
Date Posted: June 14, 2008 at 6:38 PM
That is for 2006 and up not 2005. You may be able to use a 556u.
Posted By: howie ll
Date Posted: June 15, 2008 at 1:36 AM
I believe Enice is right, I've been having problems recently with Parrot kits on late (08) models, it appears adaptor leads before '05 won't work on Post '05. If you drop the lower dash around steering colum and the ignition leads vanish into a box around 6" x 4" x 2" you will need a Fortin CAN adaptor including by-pass kit. If you have a lead with the following colours you will be OK RED / Green, RED / Blue, Light Green, BLACK/ Blue (or Blue/Black) and Purple, you are OK and use a 556U but only with the grey Valet key. My latest hands on research, i e find out when you're working on it tells me that there was a major electrical systems change about 05/6 on BMW's.
