remote start starts, then shuts down?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=105472
Printed Date: April 05, 2026 at 9:57 AM
Topic: remote start starts, then shuts down?
Posted By: drbogger
Subject: remote start starts, then shuts down?
Date Posted: June 14, 2008 at 4:59 PM
Hey Everyone,
I have a 1998 Mercury Mystique, 4 Cyl, that does NOT have a Factory Immobilier, because it was made in Feb. 1997, but its technicaly a 1998 model car.
I have a Boa Remote Start with Keyless Entry (Model 265B).
Now, whenever i start my car with the remote start, it starts up fine, runs for 30 seconds, then shuts down... i cant figure out why it keeps shutting down after 30 seconds...
Can someone here help me out a little?
Thanks in advanced!
Posted By: bbullers
Date Posted: June 15, 2008 at 1:59 AM
Are you sure it doesn't have an imobilizer? Sounds like one to me
------------- The Only Stupid Question, is the one Un-asked
Posted By: drbogger
Date Posted: June 15, 2008 at 8:02 AM
Yes, i'm possitive, because it last year it used to work fine, but all of a sudden the car started to shut down after 30 seconds.
Plus i called ford, and they checked for me, and they said it dont have one.
I'm totaly lost as to what is happening.
Posted By: fuzion1029
Date Posted: June 15, 2008 at 12:13 PM
Is there a tach wire hooked up? If so, then it probably just needs to be re-programed. It should be programed by turning the car on, and then immediately pushing the program button for 3 to 5 seconds. If it programs properly, then the led and/or parking lights will flash to confirm this.
Posted By: bbullers
Date Posted: June 15, 2008 at 12:30 PM
Wow, the things I forget..... I agree with Fuzion on that... Check the wire, make sure it's still connected, then try to re program it
Date Posted: June 15, 2008 at 12:34 PM
Yea, good point. If you can, before reprogramming tach, check the tach wire with a multimeter. See the thread in this forum about general tach comments if you're not sure how to do that.
Posted By: Chris Luongo
Date Posted: June 15, 2008 at 1:42 PM
The car wouldn't start at all if it had an immobilizer. So you're all set there.
As the others said, if you have tach hooked up, try to reprogram it.
Note that the Boa units have volatile memory. That is, if they lose power (as when the car's battery dies, or you remove the battery to replace it), everything has to be programmed again.
Posted By: drbogger
Date Posted: June 15, 2008 at 3:30 PM
Okay, well i got it fixed!
I was using the Voltage Feature, instead of the Tach Wire, so i just hooked up the tach wire, and it works fine so far :)
Thanks!
Posted By: drbogger
Date Posted: June 15, 2008 at 3:36 PM
It turns out what was happening, was the remote start checked for the voltage increase from the alternator, and i guess because my radiator fan is electric, and between that and my A/C Fan, it was making the voltage decrease too much... so now that im using the tach. wire, its working alot better now :)
